Gmoccapy - buildbot problems
18 Sep 2013 02:38 #38957
by mariusl
Regards
Marius
www.bluearccnc.com
Gmoccapy - buildbot problems was created by mariusl
Hi
Does anybody know the status of the dev buildbot problem with Gmoccapy? Has it been sorted?
Regards
Marius
www.bluearccnc.com
18 Sep 2013 09:04 #38966
Replied by cmorley on topic Gmoccapy - buildbot problems
There is still a problem with installed versions.
Chris M
Chris M
18 Sep 2013 12:27 #38970
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - buildbot problems
Thanks Chris. Is there a quick fix if I want to use the buildbot? Or some sort of instruction to follow to correct what is missing?
Regards
Marius
www.bluearccnc.com
18 Sep 2013 12:57 #38972
Check /usr/share/gscreen for a folder named skins
If you only see images the that is a problem.
You could copy the folder from a RIP system it would be found in RIP_FOLDER/share/gscreen
Chris M
Chris M
19 Sep 2013 00:35 #38995
by newbynobi
Replied by newbynobi on topic Gmoccapy - buildbot problems
Unfortunately I am not able to help with that problem, because I have no idea about the builbot version and the making of it.
Would it be a help, if I place the actual files in the WIKI as download?
Norbert
Norbert
19 Sep 2013 00:59 #38997
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
I dont think that is good practice. It would be preferable for the buildbot to work correctly. I think most of us that use LCNC on a regular basis on behalf of other people find it better to use the buildbot. I normally try and put as little other stuff on a customer machine to ensure that they dont fiddle and dont get confused.
I tend to not want to modify standard working stuff unless it is really required. Custom work always becomes a nightmare to maintain
Regards
Marius
www.bluearccnc.com
19 Sep 2013 07:16 #39012
I almost have it fixed - possibly tonight.
Chris M
Chris M
22 Sep 2013 04:56 #39097
proving to be difficult.
I have little experience with Makefiles or debs
I have asked for help on the maillist...
Chris M
Chris M
22 Sep 2013 14:51 #39100
by mariusl
Regards
Marius
www.bluearccnc.com
Thanks for the effort Chris. We do appreciate that you are going at it.
Make files are the magic of the Gurus.
Regards
Marius
www.bluearccnc.com
23 Sep 2013 11:25 #39123
I pushed some work on this, could someone check to see if the files are present now.
Chris M
Chris M
Time to create page: 0.097 seconds
