gmoccapy tool change issue after apply
31 Jan 2016 23:09 - 31 Jan 2016 23:10 #69348
by 10K
Replied by 10K on topic gmoccapy tool change issue after apply
I'm having a similar issue.
I input a new tool on a blank tool table screen on gmoccapy, and hit "apply". If I then look at the tool.tbl file, it's empty.
I've edited the tool.tbl file directly with Mousepad. When I go into the tool table screen on gmoccapy, it pulls up the data from the file. But if I hit "apply", the tool information disappears. And when I check the file, it's empty again.
I deleted the tool.tbl file. If I hit "apply", the file is recreated, but it's empty.
In no case have I ever been able to load the tool (tool not found), or set any offsets using the buttons.
Any ideas?
Versions:
Linux Jessie 32-bit
LinuxCNC 2.8.0-prel-1468-gl70bb5a
gmoccapy 1.5.6
Any ideas?
Versions:
Linux Jessie 32-bit
gmoccapy 1.5.6
Last edit: 31 Jan 2016 23:10 by 10K. Reason: typo
The following user(s) said Thank You: newbynobi
01 Feb 2016 17:11 #69372
by newbynobi
Replied by newbynobi on topic gmoccapy tool change issue after apply
Let me check on this, it works in 1.5.5.4 with 2.6.12 but show the described behavior on 1.5.6, but I did not make any change to that part of gmoccapy.
I will check on that.
Norbert
Norbert
The following user(s) said Thank You: 10K
01 Feb 2016 18:45 #69379
by newbynobi
I found out, that the strange behavior comes from the gladevcp tooledit_widget.
It has archived several changes in master, but 2.7 is fine.
So I work around could be downgrade to 2.7.
I mailed already to the developers list and ask Chris Morley and Balestrino to review there changes.
I'll keep you informed.
Norbert
Norbert
01 Feb 2016 20:01 #69384
Replied by cmorley on topic gmoccapy tool change issue after apply
Norbert
Did you test with Jessie or wheezy?
Chris M
Chris M
01 Feb 2016 20:16 #69389
by newbynobi
Hallo Chris,
with both, the tool table disappears on both installs.
As far as I found it is related to the wear offset stuff.
Norbert
Norbert
01 Feb 2016 20:25 #69390
k thanks
01 Feb 2016 22:54 #69402
I have pushed a fix to master.
There was a line commented out when i should not have beem
Chris M
Chris M
02 Feb 2016 16:35 #69461
by 10K
I downloaded the two files
from
and overwrote the files in
That fixed the problem!
Thanks for the quick fix.
tooledit_gtk.glade
tooledit_widget.py
from
https://github.com/LinuxCNC/linuxcnc/tree/master/lib/python/gladevcp
/usr/lib/python2.7/dist-packages/gladevcp
03 Feb 2016 03:13 #69480
Glad it was an easy fix! thanks for reporting.
Chris M
Chris M
Time to create page: 0.072 seconds
