Gmoccapy Spindle Configuration - OPEN LOOP
- mmprestine
19 Feb 2015 02:52 #56093
by mmprestine
Gmoccapy Spindle Configuration - OPEN LOOP was created by mmprestine
Recently just re-configuring after a PC failure and I have now dumped from memory how I had the spindle setup in Gmoccapy.
Here are the details of my needs:
DC spindle is controlled open loop with a 0-10v analog output signal to a drive.
Control works fine but I need the display to feedback the commanded output. IE with S2000 I need the display to show 2000rpm.
I see that there are Gmoccapy hal inputs but what HAL objects do I connect to to get the commanded speed returned to the screen?
Matt
Matt
19 Feb 2015 05:32 #56102
by newbynobi
Replied by newbynobi on topic Gmoccapy Spindle Configuration - OPEN LOOP
Hallo Matt,
Do you mean the spindle feedback bar?
You can use motion or halui pin.
Norbert
Norbert
Time to create page: 0.061 seconds
