Gmoccapy HELP!
20 Jul 2015 00:24 #60764
by awilcox
Gmoccapy HELP! was created by awilcox
I am attempting to setup gmoccapy and I need a little help.
I successfully installed version 2.6 from the iso so I am working with version 1.3. I modified the ini file (per the wiki) and now I get a gmoccapy2 file error. I copied the file to the config folder but I still get the error message.
Any help with this matter would be greatly appreciated.
TIA
Adrian
TIA
Adrian
24 Jul 2015 03:48 #60866
by newbynobi
Replied by newbynobi on topic Gmoccapy HELP!
Please post your config folder and give a detailed error description!
24 Jul 2015 05:31 #60869
by BigJohnT
Replied by BigJohnT on topic Gmoccapy HELP!
Please use the LinuxCNC manual for your reference, the wiki may not be up to date.
JT
JT
24 Jul 2015 18:26 #60880
by awilcox
Replied by awilcox on topic Gmoccapy HELP!
Thanks for responding to my question about gmoccapy setup. I am trying to learn how to code so I can make enhancements in the future and bring value to the forum.
JT - I will try again using the manual to see if I get a different result.
newbynobi - how do you copy the contents of the error message so it can be posted? I see others have done it so it is possible. I need to brush up on my unix/Linux commands!
Thanks again for your help!
Adrian
Adrian
24 Jul 2015 21:30 #60885
by BigJohnT
The following user(s) said Thank You: awilcox
Time to create page: 0.076 seconds
