gmoccapy user created message HAL pins?
- LearningLinuxCNC
- Topic Author
- Thank you received: 61
23 Jul 2015 10:19 #60841
by LearningLinuxCNC
gmoccapy user created message HAL pins? was created by LearningLinuxCNC
In the gmoccapy manual section it references that there are user created message HAL pins but I don't seem them in my configuration. How do I get them added to my configuration? How do I change the message displayed? Does not appear to be much information on this topic but I have a use for it if it does exist.
5.8. User Created Message HAL Pins
gmoccapy may react to external errors, using 3 different user messages:
All are HAL_BIT pin.
Status
gmoccapy.messages.statustest
Yesnodialog
gmoccapy.messages.yesnodialog
gmoccapy.messages.yesnodialog-waiting
gmoccapy.messages.yesnodialog-responce
Okdialog
gmoccapy.messages.okdialog
gmoccapy.messages.okdialog-waiting
23 Jul 2015 12:09 #60842
Replied by cmorley on topic gmoccapy user created message HAL pins?
you add them to the INI file.
www.linuxcnc.org/docs/2.6/html/gui/gmocc...he_display_section_a
scroll down that a bit...
hris M
hris M
The following user(s) said Thank You: LearningLinuxCNC
- LearningLinuxCNC
- Topic Author
23 Jul 2015 19:58 #60855
by LearningLinuxCNC
Yep I remember seeing that now. Can we put a reference to the definition section in the hal pin section in the documentation so it is easier to follow.
It is amazing how much you can read and not comprehend until you have an application to use it for. Maybe it is just me.
Replied by LearningLinuxCNC on topic gmoccapy user created message HAL pins?
hris M
24 Jul 2015 05:33 #60870
by BigJohnT
Nope, you only grasp about 10% each time you read. The trick is knowing where to look to answer your questions.
JT
Replied by BigJohnT on topic gmoccapy user created message HAL pins?
JT
24 Jul 2015 22:55 #60888
by LAIR82
You create these in your INI " DISPLAY " section and then connect them in your post-gui file, here's an example,
INI Entries,
MESSAGE_BOLDTEXT = LUBE SYSTEM FAULT
MESSAGE_TEXT = LUBE FAULT
MESSAGE_TYPE = okdialog
MESSAGE_PINNAME = lube-fault
MESSAGE_BOLDTEXT = NONE
MESSAGE_TEXT = X SHEAR PIN BROKEN
MESSAGE_TYPE = status
MESSAGE_PINNAME = xpin
Post Gui Entries,
net gmoccapy-lube-fault gmoccapy.messages.lube-fault
net gmoccapy-lube-fault-waiting gmoccapy.messages.lube-fault-waiting
net gmoccapy-xpin gmoccapy.messages.xpin
I have about 20-30 of these on each of my 4 machines that are using Gmoccapy or Gscreen.
Rick
Replied by LAIR82 on topic gmoccapy user created message HAL pins?
5.8. User Created Message HAL Pins gmoccapy may react to external errors, using 3 different user messages: All are HAL_BIT pin. Status gmoccapy.messages.statustest Yesnodialog gmoccapy.messages.yesnodialog gmoccapy.messages.yesnodialog-waiting gmoccapy.messages.yesnodialog-responce Okdialog gmoccapy.messages.okdialog gmoccapy.messages.okdialog-waiting
INI Entries,
Post Gui Entries,
Rick
- LearningLinuxCNC
- Topic Author
26 Jul 2015 01:27 #60924
by LearningLinuxCNC
Rick,
Thanks for the examples. It is very helpful.
Jim
Jim
