Gmoccapy Feedrate Overide Feed Display?
24 Sep 2016 17:09 #80858
by probamo
Replied by probamo on topic Gmoccapy Feedrate Overide Feed Display?
Used to use, and still use Vectric Aspire. Save files in EMC2 post processor, or modified mine based on the mentioned one (attached hereafter). Before in 2.6.12 everything was shown well, but after upgrading only feed in missing. This morning I cut some kitchen cabinets too, everything passed well in programmed feed rate, though feed was shown as 0. Really strange.
25 Sep 2016 10:08 #80892
by newbynobi
Replied by newbynobi on topic Gmoccapy Feedrate Overide Feed Display?
Hallo probamo,
I finally found the reason
The read ahead is in the new branch so fast, that we will not see the feed, because M2 is reached before the first cut is even made!
To check that also from your side, please edit the file and put at first and last line just % and errase the M2
Now you should see the last coded feed, not the actual one.
Norbert
Norbert
04 Oct 2016 16:52 #81223
by probamo
sorry for late feedback. To me the same, but why, what could be the reason?
04 Oct 2016 21:08 #81233
by newbynobi
Time to create page: 0.184 seconds
