Gmoccapy - Tool Number Zero
02 Oct 2015 20:07 #63368
by jschulze
Gmoccapy - Tool Number Zero was created by jschulze
Sorry if this have been covered elsewhere, but I was unable to find any info.
When using gmoccapy is there a way to make the tool information to list tool zero as it does on startup? When I want to unload the tool in the spindle I use M6T0 which calls a toolchange subroutine, unloads the tool, and uses M61Q0 to set iocontrol.0.tool-number to -1, but the tool information in gmoccapy still lists the previously loaded tool.
Thanks,
Jordan Schulze
Thanks,
Jordan Schulze
03 Oct 2015 23:38 #63401
by newbynobi
Replied by newbynobi on topic Gmoccapy - Tool Number Zero
Hallo Jordan,
you are right, I am able to reproduce that.
If i have a tool loaded and do a T0 M6 all works like expected, but a M61 Q0 the tool information will remain and also the tool offset is still present!
I do think, that that is a bug in linuxcnc.
I also found a small mistake in my code, I will push the solution in two minutes. But after updating you will still to have to use a work around, doing the M61 Q0 twice to get the tool number set correct.
I reported the error already in the developer mailing list.
Norbert
Norbert
The following user(s) said Thank You: jschulze
04 Oct 2015 00:46 #63404
by jschulze
Replied by jschulze on topic Gmoccapy - Tool Number Zero
Huge thanks for looking into it. I have remapped M6 to a subroutine controlling my atc. This was my first time remapping, so I wasn't quite sure how to retain some of the original M6 functionality, hence I use the M61 inside the subroutine to update the current tool. I suppose it would work like normal if I could retain the activation of iocontrol.0.tool-change and then tell iocontrol.0.tool-changed when the toolchange was complete.
Time to create page: 0.060 seconds
