Timing problem
- korbendallas78
20 Jan 2016 12:36 #68810
by korbendallas78
Timing problem was created by korbendallas78
Hello,
I found a problem with load gmoccapy. I made a gladevcp panel with leds. I connect to this leds some other pins in postgui.hal. With axis ui no problem. But with gmoccap ui is send message : custom_postgui.hal :13: Pin 'leds.hal_led1' does not exist.
This error message not all time. Sometimes gmoccapy is started and the hal leds working well.
I think the custom_postgui.hal loaded before the gmoccapy started.
Sorry for my english.
20 Jan 2016 12:43 #68811
Are you loading the GladeVCP with a "-W" switch?
This is likely to be more a GladeVCP timing issue that Gmoccapy.
loadusr flags are given here:
www.linuxcnc.org/docs/html/man/man1/halcmd.1.html
Replied by andypugh on topic Timing problem
- korbendallas78
20 Jan 2016 12:50 #68812
by korbendallas78
Replied by korbendallas78 on topic Timing problem
EMBED_TAB_COMMAND = loadusr -W gladevcp -x {XID} leds.glade
20 Jan 2016 12:56 - 20 Jan 2016 12:56 #68813
The manual ( www.linuxcnc.org/docs/html/gui/gladevcp.html ) suggests -Wn gladevcp, ie
This waits for a component "gladevcp" and has a -c option that I am not sure of the meaning of, but I think forces a component name, which is possibly useful if it is waiting (-Wn) for a specific component to be ready.
This is a guess, though. No guarantees expressed or implied
EMBED_TAB_COMMAND= loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} leds.glade
Last edit: 20 Jan 2016 12:56 by andypugh.
The following user(s) said Thank You: korbendallas78
- korbendallas78
20 Jan 2016 13:18 #68814
by korbendallas78
I tried. Same problem
20 Jan 2016 18:55 #68842
by newbynobi
Replied by newbynobi on topic Timing problem
@korbendallas78
I also noticed that behavior some times, I recomend the followingf, as till now it works under all circumstances perferct.
Move all the relevant hal connections from postgui.hal to hal file named leds.hal. That hal file should be in your config dir.
And load your panel like this one:
That command loads the panel and after loading it it connects the hal pin mentioned in the named hal file.
If you need, you can add your own python handler by adding -u led.py
For an example you may look at sim/gmoccapy/gmoccapy-plasma/gmoccapy-plasma.ini
Norbert
EMBED_TAB_COMMAND = gladevcp -x {XID} -H leds.hal leds.glade
Norbert
- korbendallas78
21 Jan 2016 05:18 #68868
by korbendallas78
Thank You!
It seems working perfectly.
21 Jan 2016 22:42 #68903
by newbynobi
You are wellcome!
Time to create page: 0.129 seconds
