File Open Dialog - No Network Drives
26 Jan 2016 14:36 #69118 by HDVideo
Is //windows_share/ in the mount command the full path? for example: D:data/cad_cam/toolpaths/
If for example, the "data" folder and all sub-folders are shared on the Windows system, can I eliminate the sub-folders in the mount command?
Also, are the path and filenames case sensitive?
Thanks for all the help with this issue!
26 Jan 2016 15:03 #69123 by ArcEye
The path is //server-name/window_share_name.
I don't know what your server name comes up as, but it will be whatever the file manager can access it as
D: is meaningless outside of windoze, both as a designation and because it is local to another computer
If you have access to the root directory and all sub-directories are set to allow sharing, yes you should be able to just specify the root directory and then navigate to others as required, just as you would on a local file system.
Always in Linux
I don't know a huge amount about file sharing with windoze on a practical level, because I negate the need for it, by not using windoze, or just transfer files on a USB stick if I cannot avoid it :P
Others may well have practical tips for the easiest methods of connection etc.
The following user(s) said Thank You: HDVideo
26 Jan 2016 16:40 - 26 Jan 2016 16:42 #69125 by Todd Zuercher
Depending on what your windows computers name is. If it is "windows-pc" the path would be
//windows-pc/data/cad_cam/toolpaths/
Last edit: 26 Jan 2016 16:42 by Todd Zuercher.
26 Jan 2016 19:06 #69128 by HDVideo
I think I'm almost there, but still getting Access Denied errors on the mount command. It's asking for a password when the command is entered and I've tried my LinuxCNC system password as well at my Windows password with the same results. Attached is a screen grab if anyone has an idea what I'm doing wrong. The folder winbox has been created in the nc_files folder.
26 Jan 2016 21:17 - 26 Jan 2016 21:23 #69134 by Todd Zuercher
The password prompt after issuing a sudo command will be your linux password.
You can add at the end of the comand -o username=your_windows_user_name, password=your_password
sudo mount.cifs  //video-pc/cad_cam/Aspire/Toolpaths/  home/ed/linuxcnc/nc_files/winbox/ -o username=your_windows_user_name,password=your_windows_password
Last edit: 26 Jan 2016 21:23 by Todd Zuercher.
26 Jan 2016 21:59 #69136 by HDVideo
I did try that earlier and received a different error that I forget at the moment. I think it was a syntax error of some sort, so I'll give it another try. The Windows shares were all made public so no password should be needed, I would think, but not really sure.
29 Jan 2016 19:00 #69252 by HDVideo
Woo-Hoo - Finally got it to work!
I was getting "Failed to open Windows Network - Failed to retrieve share list from server" errors for a couple of days, but once that was fixed, the mount.cifs command worked. The problem I was having before the "Failed to open..." error popped up was I needed to put // in front of home in the command line. I also needed the username/password to make it work.
Now to see if I can modify the fstab file to make the mount permanent.
Thanks a bunch for helping us Linux challenged users! I really appreciate it.
Ed
07 Jul 2016 07:09 - 07 Jul 2016 07:11 #77129 by eFalegname
Hi Ed, II did not succeed to do the mount with cifs. :sick:
Found the directory where linuxmint mounts my network drive then I linked it to my nc_file directory.
ln -s -f '/run/user/1000/gvfs/smb-share:server=192.168.1.1,share=volume(sda1)/BM' '/home/ef/linuxcnc/nc_files'
Now I have to mount the network drive at startup
Last edit: 07 Jul 2016 07:11 by eFalegname.
07 Jul 2016 10:59 - 07 Jul 2016 21:11 #77136 by eFalegname
Ok, I have some updates maping my USB router network drive to share:
My linuxcnc runs on linuxmint mate 17.3 with cifs-utils installed by default. Anyway you can install cifs on your system:
sudo apt-get install cifs-utils
1. In order to mount the shared drive I created a directory named BM inside the nc_files:
sudo mkdir /home/ef/linuxcnc/nc_files/BM
2.Opened the fstab file and added a row to link the USB router drive (remote "BM" directory) inside my nc_files directory with the "BM" local. This mounts the network drive at linux startup:
sudo pluma /etc/fstab
//192.168.1.1/volume(sda1)/BM	/home/ef/linuxcnc/nc_files/BM	cifs guest,rw,uid=1000,gid=1000,nounix,iocharset=utf8,file_mode=0777,dir_mode=0777  0	0
3.Saved and reloaded fstab file
sudo mount -a
options meaning:
cifs - partition type
guest - no password protect connection required
rw - mount read/write rights
uid and gid - user id. You can retrieve it with the command:
cat /etc/passwd | grep your-linux-username
nounix - disable cifs unix extensions so that no UNIX ACL, path and lock will be used.
iocharset - non english languages character support
mode - permissions
0 - back up drive
0 - fsck command (at boot time)
Fstab Ubuntu-help
Last edit: 07 Jul 2016 21:11 by eFalegname.
Moderators: newbynobiHansU
