screen resolution
13 Apr 2016 14:53 #73235
by dinkata
screen resolution was created by dinkata
The minimum screen resolution for gmoccapy, using it without side panels is 979 x 750 Pixel.
Is it possible 800x600 for touch panel 12" .
I opened /usr/share/gmoccapy/gmoccapy.glade with Glade .
File read-only .Please tell Is it possible resolution 800x600 ?
13 Apr 2016 21:03 #73253
by newbynobi
Replied by newbynobi on topic screen resolution
Change the file rights and edit it to your needs.
Do ot delete or rename widgets and all should be fine!
14 Apr 2016 07:03 #73276
by newbynobi
14 Apr 2016 13:00 #73296
by dinkata
Replied by dinkata on topic screen resolution
14 Apr 2016 16:44 #73315
by newbynobi
Strange, one post got lost and all the links and code
Very strange, so here again:
Gmoccapy 800x480
Norbert
Gmoccapy 800x480
Norbert
The following user(s) said Thank You: dinkata
16 Apr 2016 02:53 #73385
by dinkata
Thank You
Thank You
Thank You
Thank You
Thank You
17 Apr 2016 07:37 #73461
by dinkata
gmoccapy_lcd7
Yes, I like it ,for now I see no keyboard in tool table editor
02 Jun 2016 14:45 #75338
by RotarySMP
Replied by RotarySMP on topic screen resolution
Hello Dinkata, did you reconfigure GMOCappy to 800x600? I also have 10" screen with this resolution, and intend to use it for a Lathe controller.
Mark
Mark
17 Aug 2016 13:07 - 18 Aug 2016 04:16 #78930
by dinkata
I use gmocappy_lcd 7 on 12" touch screen monitor for LatheHello Dinkata, did you reconfigure GMOCappy to 800x600?
Mark
Last edit: 18 Aug 2016 04:16 by dinkata.
- Thank you received: 5908
17 Aug 2016 19:48 #78957
Regards,
Tom
Replied by tommylight on topic screen resolution
Dang that is a nice setup. I can read "rucen hod" so that is Russian, right?? Meaning "manual movement" ???
Mark
Regards,
Tom
Time to create page: 0.199 seconds
