Keyboard Shortcuts in Gmoccapy
- LearningLinuxCNC
- Topic Author
- Thank you received: 61
02 May 2016 01:22 #74117
by LearningLinuxCNC
Keyboard Shortcuts in Gmoccapy was created by LearningLinuxCNC
Norbert,
Is there a way to add additional keyboard shortcuts other than what is covered in the documentation?
Thanks,
Jim
Keyboard shortcuts
Some users want to jog there machine using the keyboard buttons and there are others that will never allow this. So everybody can select whether to use them or not.
Default is to use keyboard shortcuts.
Please take care if you use a lathe, than the shortcuts will be different. See the Lathe section
Arrow Left = X minus
Arrow Right = X plus
Arrow up = Y plus
Arrow Down = Y minus
Page Up = Z plus
Page Down = Z minus
F1 = Estop (will work even if keyboard shortcuts are disabled)
F2 = Machine on
ESC = Abort
Thanks,
Jim
02 May 2016 15:12 #74141
by newbynobi
Replied by newbynobi on topic Keyboard Shortcuts in Gmoccapy
There are already additional keys:
<SHIFT> <SPACE> will delete all messages
<SUPER_L> = Left windows key will delete last message
<F3> change to manual mode
<F5> change to MDI Mode
<RETURN> will emit the mdi command if you are in MDI mode
<I> change increment button to the next one
<i> change increment button to the previous one
I unfortunately did not have time to update the documentation.
Could you add this ones to the doku please and I may think of adding one or two more
You will find the documentation file to be updated under:Just edit it and send it to me or the developers list, so it can be pushed.
Norbert
P.S. You may also add the keys you want in the gmoccapy.py file, editingaround line 1858
/linuxcnc-dev/docs/src/gui/gmoccapy.txt
Norbert
def on_key_event
The following user(s) said Thank You: tivoi, LearningLinuxCNC
- LearningLinuxCNC
- Topic Author
02 May 2016 15:29 #74143
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Keyboard Shortcuts in Gmoccapy
I will update the documentation. I also did some playing around last night and found that shift+arrow or shift+pgup, shift+pgdn is rapid same as in axis.
I may play around with adding some custom keycodes just for fun and curiosity.
Thanks a bunch.
Jim
Thanks a bunch.
Jim
03 May 2016 20:50 - 03 May 2016 20:51 #74199
by newbynobi
What more keys do you need?
May be interesting also for others.
And many thanks for your support on the documentation. I am running out of time at the moment, too much orders at the moment, and i need / want the money
Norbert
Norbert
Last edit: 03 May 2016 20:51 by newbynobi.
- LearningLinuxCNC
- Topic Author
04 May 2016 12:12 #74220
by LearningLinuxCNC
I am building a custom HMI control panel(s) for my machine(s). These control panels will have keys for the normal things like jogging, spindle control, coolant control, and a G-Code keypad for entering MDI commands. The other thing that will be on the control panel is an mpg. This mpg will control the selected axis, spindle speed override, feed override, etc. The interface to the computer for this control panel will be a HID Keyboard interface. So all of these commands will come as keystrokes.
I am planning on getting my prototype built and then offering custom control panels for sale to the CNC community. The plan would be to provide a panel that could work with the Axis GUI as well as the Gmoccapy GUI or any other for that matter. Maybe even Mach (TBD).
I really like the touchscreen interface that Gmoccapy offers, but there is a lack of tactile feedback especially when looking away from the screen. You don't always know what button your finger is on. Also the on screen keyboard is less than friendly at times so this HMI interface panel will solve both of those problems.
I will play with the ability to add keystrokes to Gmoccapy and let you know which ones I want in the published version.
Thanks,
Jim
Thanks,
Jim
04 May 2016 15:05 #74229
by newbynobi
Hallo Jim,
all what you do, can be done "without" touching the gmoccapy file, just using somethink like:
Please find attached my pendant configuration based on a keyWarior chip connected to USB as HID
Norbert
loadusr -W hal_input -K +KeyWarrior:0
Norbert
The following user(s) said Thank You: LearningLinuxCNC
- LearningLinuxCNC
- Topic Author
04 May 2016 16:06 #74234
by LearningLinuxCNC
Yep, I completely overlooked the hal_input module. I will give that a shot.
Thanks,
Jim
Thanks,
Jim
28 May 2016 20:37 #75196
by tarasko
Replied by tarasko on topic Keyboard Shortcuts in Gmoccapy
Excuse me.
In what version of gmoccapy <F3> and <F5> are works as switching to the manual, mdi mode?
29 May 2016 17:44 #75222
by newbynobi
F3 and F5 shortcuts have been introduced with gmoccapy 1.5.5.
You must enable keyboard use in settings to use that feature.
Norbert
Norbert
The following user(s) said Thank You: tarasko
20 Aug 2016 13:42 #79125
by tarasko
Well, there is some bug around these shortcuts.
I'm using a touchscreen monitor with hardware keyboard.
I found it more convenient than on-screen keyboard.
So I frequently switching among MANUAL, AUTO, MDI modes.
I think switching from AUTO -> MDI mode not works properly.
(the case when I want directly switch to MDI mode (F5) after program end)
I also reproduced this issue in recent Gmocappy 2.1.0 from master branch
Thanks.
Norbert
Norbert
Thanks.
Time to create page: 0.096 seconds
