Gmoccapy preview not working on some files
20 May 2016 21:13 #74896
by morph
Gmoccapy preview not working on some files was created by morph
I wasn't able to figure out why this happens, but some file won't show g-code preview.
I'm guessing its related to filesize, because usually it happens on bigger files.
Any hints how to resolve this? because i need the "run from line" feature, which can't be used...
21 May 2016 22:19 - 21 May 2016 22:20 #74926
by morph
Replied by morph on topic Gmoccapy preview not working on some files
ok, pretty simple solution: avoid ü,ä,ö characters in your file. This maybe applies to kyrilic chars too.
Otherwise you will just see an empty file in preview.
Last edit: 21 May 2016 22:20 by morph.
23 May 2016 16:56 #74995
by newbynobi
Replied by newbynobi on topic Gmoccapy preview not working on some files
@morph,
what version do you use? I thought I solved that problem.
What software do you use to generate your code?
Norbert
Norbert
23 May 2016 20:52 #75006
by morph
no idea
i'm using gmoccapy that is packed with the uspace master branch (currently 2.8..... whatever)
is there a way to look up the included gmoccapy version?
25 May 2016 15:55 #75076
by newbynobi
Yes, of course
Just go on the settings page and look at the bottom button place;-)
Could you post a corrupt file, as I do not have that problem here.
Norbert
Norbert
Time to create page: 0.096 seconds
