gmoccapy changes display from G55 to G54
29 May 2016 12:13 - 29 May 2016 12:14 #75219
by ttontsa
gmoccapy changes display from G55 to G54 was created by ttontsa
Hi
While i make G55 command in mdi mode current axis display changes and stays to G55.
While i turn to auto mode-> load file -> hit Run program gmoccapy changes current axis to G54. Program goes through correct with G55 coordinates.
If i like to use manual mdi codes after runned program i have to remember give every time in mdi mode command G55 or else i fuck up my work, tools etc etc..
Programs starts i have line:
G21 G40 G90 G55 G64 P0.01
Why current axis display wont stay G55?
Last edit: 29 May 2016 12:14 by ttontsa.
29 May 2016 17:47 #75223
by newbynobi
Replied by newbynobi on topic gmoccapy changes display from G55 to G54
06 Jun 2016 21:26 #75588
by ttontsa
Replied by ttontsa on topic gmoccapy changes display from G55 to G54
You mean M2 and M30?
I use M30. So that is not fault its feature??
So there is no way to keep G55 selected all the time?
If i end program with % G55 stay correct but its said that use of % is not recommended. Program gives also error message about usage of % but works. Its said that The state of machine is quite a random on the beginning of next move.
07 Jun 2016 20:30 #75659
by newbynobi
Yes M2 and M30:-)
Use % at first and last sign / line in your program to stay in G55.
Norbert
Norbert
Time to create page: 0.322 seconds
