Spindle GtkHscale[scl_spindle] error
- korbendallas78
04 Jun 2016 13:16 #75486
by korbendallas78
Spindle GtkHscale[scl_spindle] error was created by korbendallas78
Dear,
In the gmoccapy, the GtkHscale[scl_spindle] does not change the spindle speed pins (motion.spindle-speed-out,etc.) in negative direction. In positive direction its work perfectly. Pls help!
05 Jun 2016 14:56 #75523
by newbynobi
Replied by newbynobi on topic Spindle GtkHscale[scl_spindle] error
Please post you config. I am pretty sure it is a config error.
Scl_spindle is for spindle override, not for the spindle revs.
Norbert
Norbert
- korbendallas78
06 Jun 2016 04:23 #75538
by korbendallas78
Replied by korbendallas78 on topic Spindle GtkHscale[scl_spindle] error
I' ve tried in many configuration. Same problem. I checkink the motion.spindle-speed-out , motion.spindle-speed-out-abs, motion.spindle-speed-out_rps, motion.spindle-speed-out-rps-abs in the Hal Meter. If the spindle is turn on negativ direction this values doesn't change in the Hal Meter. If the spindle turn the positve direction it changes. Please try it, you will see!
- korbendallas78
06 Jun 2016 04:36 #75539
by korbendallas78
here is a config
- korbendallas78
06 Jun 2016 06:44 #75540
by korbendallas78
I want to control the vfd on modbus, that i need the motion.spindle-speed-out-abs pin.
- korbendallas78
07 Jun 2016 05:07 #75607
by korbendallas78
gmoccapy.spindle-override.direct-value isn't change if move the scale and the spindle direction is ccw
07 Jun 2016 20:23 #75657
by newbynobi
It is an IN Pin, so it is correct not to change!!!!
May be i find some time next week to look at this. A short look in your hal file shows, that you have not configured spindle ccw no hal connection to that kind of pin!
Please test with gmoccapy sim and report if that do work.
Norbert
Norbert
- korbendallas78
13 Jun 2016 05:24 #75897
by korbendallas78
I tested with sim, but it doesn't work. There is strange things if i change the rotation direction.
13 Jun 2016 20:13 #75936
by newbynobi
I will test that asap.
Give me a few weeks, as I am busy with a scara , a gantry and a lathe rebuild.
Norbert
Norbert
14 Jun 2016 07:31 - 14 Jun 2016 07:37 #75960
by newbynobi
@korbendallas78,
as I could not sleep, due to the behavior you described, I tested with configs / sim / gmoccapy / gmoccapy.ini
with Linuxcnc 2.7 and gmoccapy 1.5.6.1 and with master and gmoccapy 1.5.6.3
So no bug or error on my side.
Norbert
- get out of estop
- switch the machine on
- home all axis
- goto MDI page and enter S2000 M3
- goto settings page
- click on button halshow
- add to watch tab * motion.spindle-speed-out-rps
- go back to manual tab
- change the slider and you will see values do change
- stop the spindle pressing the stop button
- values are zero
- start spindle in reverse and watch the values
- change the override slider and you will see the values do change
* motion.spindle-speed-out-abs
Norbert
Last edit: 14 Jun 2016 07:37 by newbynobi.
The following user(s) said Thank You: korbendallas78
