gmoccapy 2.1.0 has been released
03 Sep 2016 09:49 #79964
by dinkata
There is correct
Replied by dinkata on topic gmoccapy 2.1.0 has been released
Excuse me, I tried configs/sim/gmoccapy/gmoccapy_lathe.ini .Please try with configs/sim/gmoccapy/gmoccapy_lathe.ini
There is correct
03 Sep 2016 10:00 #79967
by newbynobi
Replied by newbynobi on topic gmoccapy 2.1.0 has been released
OK, than it is for sure your config.
Norbert
Norbert
- Dale Lusby
06 Sep 2016 13:02 #80073
by Dale Lusby
After I changed this parameter in the config I was able to get it to work. Now time to play with the 2.1
Replied by Dale Lusby on topic gmoccapy 2.1.0 has been released
Well ok. You even didn't compile it correctly.
First you need to launch configure script with additional parameter as been sain in error message:
./configure --enable-non-distributable=yes
Then continue with compilation as instruction says.
After successful compilation you need to launch linuxcnc script:
~/linuxcnc-dev/scripts/linuxcnc ~/<some_location>/<your_configuration_ini_file>
31 Dec 2016 21:15 - 31 Dec 2016 21:15 #84974
by Hakan
Replied by Hakan on topic gmoccapy 2.1.0 has been released
A bit old for this thread maybe. Anyway.
I have a nagging issue when using a joypad for jogging on the lathe.
It worked fine in 1.x and in general it works fine also in the latest 2.1.
However, if I for example touch off, enter a value and then try to jog
with the joypad keys it won't work. I need to manually press one of the
X-/X+/Z-/Z+ buttons in gmoccapy with the mouse. Just a press
seems enough. Then the jogging with the joypad keys works again.
Until a new user input on the gmoccapy screen is needed.
The joypad is controlled by
loadusr -W hal_input -KRAL F310
Do you have an idea of what this can be?
Thanks.
Thanks.
Last edit: 31 Dec 2016 21:15 by Hakan.
01 Jan 2017 14:20 #85010
by newbynobi
That is strange,
What version do you use?
I just pushed release 2.2.0.2
I have not seen such a behavior with my two "handwheels" but I use MPG for jogging, not button.
If you update and start from terminal, you would see printed the mode changes.
Setting a value is done in MDI mode, while jogging is allowed only in manual mode.
Depending on your config, there might be a race conflict in mode changes.
Norbert
Norbert
01 Jan 2017 18:03 #85030
by Hakan
I tested now with the latest 2.2.0.2 I think.
I too use a MPG in my milling machine and that works as it should
I looked at the mode change debug output and that seems to happen at the right time.
What I also get is
The "wrong motion mode" message come when I press X+/X-/Z+/Z- in gmoccapy after using the joypad.
After that the jogging with the joypad works.
What I also get is
MANUAL Mode
wrong motion mode, change to the correct one
3 2
('MDI Mode', False)
01 Jan 2017 21:36 #85038
by newbynobi
The wrong motion mode comes from joint axis handling
What hal pin do you use for jogging?
Please post your config.
Norbert
Norbert
- racedirector
- Thank you received: 41
04 Jan 2017 12:44 - 04 Jan 2017 17:10 #85196
by racedirector
Replied by racedirector on topic gmoccapy 2.1.0 has been released
Quick question.....will this version work with 2.7.8? Was going to download all the required files and do a re-make of the source to get V2+ if it does.
No!
It will not!
If you want to use v2+ with 2.7, you will need to change some code. The main difference is that I changed gmoccapy to support the new Joint/Axis changes from 2.8
If you just want to use the new slider Widgets, that can be done with a reasonable amount of gode modifications.
Because I do support at the moment 3 release versions (gmoccapy in 2.6, gmoccapy in 2.7 and gmoccapy in 2.8) I have not many time to make special wishes come True
I will announce very soon, that gmoccapy in 2.6 will not be supported any more, as users should update to 2.7
Norbert
No!
It will not!
Norbert
Last edit: 04 Jan 2017 17:10 by newbynobi.
04 Jan 2017 17:11 #85240
by newbynobi
@Hakan,
I still need to know what hal pin you use for jogging to solve that issue!
Norbert
Norbert
05 Jan 2017 10:11 #85276
by Hakan
Of course.
I first want to go through my configuration to see if I can find anything myself.
I will come back with info during the weekend.
/Hakan
/Hakan
Time to create page: 0.161 seconds
