jog velocity from mm/min to mm/sec
19 Sep 2016 12:46 #80603
by mpvriens
jog velocity from mm/min to mm/sec was created by mpvriens
Hi is it possible to change the velocity from mm/min to mm/sec
Marius
Marius
19 Sep 2016 21:03 #80634
by newbynobi
Replied by newbynobi on topic jog velocity from mm/min to mm/sec
Hallo Marius,
There are two possibilities
1. Change the code frome gmoccapy
2. Change the velocities using hal connection with scales
What is the reason for your wish to change that?
It is unusual.
Norbert
It is unusual.
Norbert
20 Sep 2016 10:41 #80661
by mpvriens
Replied by mpvriens on topic jog velocity from mm/min to mm/sec
Hi Norbert,
Reason, we have different machines (like multicam) who work with mm/sec, we would like to work with standard programs on those machines
Marius
Marius
- Thank you received: 1369
20 Sep 2016 12:30 #80666
Replied by Todd Zuercher on topic jog velocity from mm/min to mm/sec
It would be simple to create a script that converts your F-codes from mm/s to mm/m while the file loads. And since you will likely need a conversion script anyway if you are going to want to run code made for other machines.
20 Sep 2016 14:31 #80672
by mpvriens
Is true, only challenge will be , if you want to work with the different machines you have to be aware which machine you are working on, as in MDI mode F60 on one machine will be F3600 on the onther one.
20 Sep 2016 14:52 #80674
Perhaps you could remap the F-word?
linuxcnc.org/docs/html/remap/remap.html
The following user(s) said Thank You: newbynobi
