halui.spindle-override.increase bug ?
27 Sep 2016 09:28 #80980
by dinkata
Replied by dinkata on topic halui.spindle-override.increase bug ?
Congratulations, now working !YEEESSSSS!
27 Sep 2016 13:08 - 27 Sep 2016 13:53 #80996
by newbynobi
Replied by newbynobi on topic halui.spindle-override.increase bug ?
OK, so one done, one to go
Hope pippin88 will be satisfied too.
Norbert
P.S. By the way, I see you do use hal_manualtoolchange and not the gmoccapy tool change, any reason for that?
Norbert
Last edit: 27 Sep 2016 13:53 by newbynobi.
The following user(s) said Thank You: pippin88
28 Sep 2016 03:38 #81021
by dinkata
this configuration I did just to show problem , at work I use other !P.S. By the way, I see you do use hal_manualtoolchange and not the gmoccapy tool change, any reason for that?
28 Sep 2016 06:33 #81024
by pippin88
Replied by pippin88 on topic halui.spindle-override.increase bug ?
Norbert,
Thank you!!! The fix works greats. All is working now. I was having problems with reverse before, now that is fixed also it seems.
I have also fixed my config to use gmoccapy tool change.
Is there a way I can make a donation for your efforts?
Time to create page: 0.120 seconds
