gmoccapy macro pop up prompt
25 Sep 2016 10:18 #80895
by pippin88
gmoccapy macro pop up prompt was created by pippin88
I would like to have a pop up at the start of a macro that requires the user to click continue, like when starting a program and there is a pop up about load tool x and click continue.
This to to make sure the user has the correct tool in the spindle and any other things they need to do.
For example, I want to have a macro for surfacing the router spoil board.
There should be a pop up that says "Ensure 22mm surfacing bit is in spindle and there is nothing on the table" - then user must click continue.
Is this possible?
Thanks,
Nick
Is this possible?
Thanks,
Nick
25 Sep 2016 13:56 - 25 Sep 2016 13:56 #80905
by newbynobi
Replied by newbynobi on topic gmoccapy macro pop up prompt
Last edit: 25 Sep 2016 13:56 by newbynobi.
26 Sep 2016 09:39 #80926
by pippin88
Replied by pippin88 on topic gmoccapy macro pop up prompt
Norbert,
Thanks for the reply. I was hoping for something much simpler, like the "(MSG, It is done!)" in the macros already, but with a pop up requiring the user to click continue.
If a method like MSG or DBG does not exist, I will look at the pins as a way of doing it.
26 Sep 2016 14:27 #80933
by newbynobi
Using the message dialogs is quite simple, you can set the according hal pin using a cusom M code, like M100.
Do not forget to reset the hal pin after the user clicks OK, otherwise it will stay hight and the next time the message will not appear.
Norbert
Norbert
10 Nov 2018 13:34 #120388
by Marcking
Hi Norbert, would you give an example of how to use this? I made the message to appear but can't make the program to pause.
Thanks!
Replied by Marcking on topic gmoccapy macro pop up prompt
Norbert
Thanks!
- islander261
- Thank you received: 216
10 Nov 2018 17:55 #120405
by islander261
Replied by islander261 on topic gmoccapy macro pop up prompt
Hi
I may no understand what you want. In my plasma configuration I need to sense probing errors and stop the Gcode program execution for operator intervention. So I use the (MSG, This Error) followed by an M0. The operator then hits the pause/run button to continue when the problem is fixed.
10 Nov 2018 17:58 #120406
by Marcking
Want to do the same but from the user created messages, already made the program to pause and now need to know how to resume after pressing OK button.
Time to create page: 0.143 seconds
