GUI Modification Plasma
20 Dec 2016 13:52 #84459
Replied by andypugh on topic GUI Modification Plasma
-W is an option of "loadusr" so is documented under
halcmd
- islander261
- Thank you received: 216
28 Dec 2016 20:13 #84822
by islander261
Replied by islander261 on topic GUI Modification Plasma
hello
Well I haven't gotten all of the starting problems fixed yet. I have moved onto other things in the mean time and will get back to this when I have more pieces finished.
One thing that puzzles me is that I cannot start halscope from the Gmoccapy maintenance menu. The button for starting halscope is there but when I select it nothing seems to happen. The rest of the buttons appear to work. Is there a special procedure for starting halscope from within Gmoccapy?
29 Dec 2016 09:08 #84843
by newbynobi
Replied by newbynobi on topic GUI Modification Plasma
I can start halscope from gmoccapy, I am not able to find any error here.
Norbert
Norbert
- islander261
30 Dec 2016 04:24 #84898
by islander261
Norbert
Thank you for checking. This might be a clue, it is the first time I have checked the terminal for this error.
The first bit is the usual error I can't trace down but the last one is new to me.
TIA
/usr/bin/gladevcp:295: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 17
gtk.main()
Settings say: do not use keyboard shortcuts, abort
rtapi_shmem_new failed due to shmget(key=0x130cf406): Permission denied
SCOPE: ERROR: failed to get shared memory (key=0x130cf406, size=272)
TIA
30 Dec 2016 17:39 #84920
by newbynobi
How have you installed?
There seems to be a permission problem.
Please run gmoccapy and then from a second terminal launch halscope, does that work?
I am sure this is not caused by gmoccapy.
gmoccapy launches the following command if you push the button:
Norbert
halscope > /dev/null &
Norbert
- islander261
30 Dec 2016 19:51 #84928
by islander261
Norbert
Thank you. Starting halscope from a separate terminal produces the same error message. It is obvious that the problem is with my installation and not with Gmoccapy. Now it is time for some research because I have no idea what the error message means.
06 May 2019 04:55 #132917
by phoenix
Replied by phoenix on topic GUI Modification Plasma
Can you pls share files for this configuration xml and hal files
Time to create page: 0.477 seconds
