Help with lathe options
04 Dec 2016 19:24 #83674
by russkinch
Replied by russkinch on topic Help with lathe options
Awesome. Thank you so much. I will send it to my PC at the workshop now and try it in the morning. Will let you know. Many thanks again
05 Dec 2016 19:46 #83698
by russkinch
Thanks Andy. I uploaded it today and ran it. It works just like I needed it to. There are only 2 small questions, I could probably Google it. First is I want to start it maximized. I suppose in the INI file there would be something I could add. Also when I tried to run it it said there was an error d1 feed cannot be zero???
05 Dec 2016 20:00 #83699
Replied by andypugh on topic Help with lathe options
1) forum.linuxcnc.org/21-axis/29735-axis-modifications#63485
2) you probably have a surface-speed of zero in the cycle that you tried to run?
05 Dec 2016 20:03 #83700
by russkinch
Thanks. You are an absolute legend. If I knew where you were I would send you a bottle of wine or case of beer. (or cokes if that's for you). Thanks again. I am so glad I found this forum as all you guys here do this in your own time and the response I have had already is amazing.
07 Dec 2016 07:30 #83731
by newbynobi
Replied by newbynobi on topic Help with lathe options
To start gmoccapy maximized you just have to set this option on the settings page of gmoccapy.
If you want to use axis, you are in the wrong thread
Norbert
Norbert
Time to create page: 0.071 seconds
