Gmoccapy from Axis- LinuxCNC not loading now...
- nigel-tufnel
29 Dec 2016 03:16 #84835
by nigel-tufnel
Gmoccapy from Axis- LinuxCNC not loading now... was created by nigel-tufnel
So I have a successful installation of Axis running and I'm attempting to switch to gmoccapy. I have edited my existing .ini file to change the DISPLAY = axis to DISPLAY = gmoccapy. Now LinuxCNC doesn't come up when launching from my existing launch icon. I have read the gmocappy document but it is hard to determine what is required to get operational and what are advanced setup options. Debug section of the error report shown below. Any suggestions? Do I need to modify my .hal file? Thanks.
Debug file information:
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
(gmoccapy:4933): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
pyvcp_options.hal:7: Pin 'pyvcp.spindle-speed' does not exist
4884
PID TTY STAT TIME COMMAND
4930
Stopping realtime threads
Unloading hal components
4884
4930
29 Dec 2016 09:05 - 29 Dec 2016 09:05 #84842
by newbynobi
That is the error that prevents linuxcnc from starting. You used a pyvcp panel with axis, but pyvcp panel do not work with gmoccapy.
Just go to your ini and comment the corresponding hal line.
Norbert
Replied by newbynobi on topic Gmoccapy from Axis- LinuxCNC not loading now...
Norbert
Last edit: 29 Dec 2016 09:05 by newbynobi.
- nigel-tufnel
30 Dec 2016 18:58 #84925
by nigel-tufnel
Replied by nigel-tufnel on topic Gmoccapy from Axis- LinuxCNC not loading now...
Thanks. I managed to find it in a seperate pyvcp_options.hal file that was called in my .ini.
Time to create page: 0.079 seconds
