Gmoccapy Bug?
- racedirector
- Thank you received: 41
06 Jan 2017 12:46 #85333
by racedirector
Gmoccapy Bug? was created by racedirector
Found something weird with both the LCNC 2.7 and 2.8 versions of gmoccapy.....
With a file running press Pause, then press Stop. In both versions the spindle turned off but the axis moved as it was doing so, ala Mach3. I did not expect this so I didn't bother to raise the Z from where it was and the machine dragged the slowing bit through the job until whatever was stored in whatever buffer ran out.
I know this isn't a LinuxCNC thing 'cause Axis and PathPilot don't do it, they just stop the spindle in the above scenario.
Pressing just Stop works "as intended", Spindle stops and the axis' don't move at all.
06 Jan 2017 22:10 - 06 Jan 2017 22:11 #85362
by newbynobi
Replied by newbynobi on topic Gmoccapy Bug?
I will chech as soon as possible,
I have not noticed that.
Norbert
Norbert
Last edit: 06 Jan 2017 22:11 by newbynobi.
07 Jan 2017 10:41 #85392
by newbynobi
@racedirector,
I could only test with sim, as I destroyed yesterday my spindle and have disarmed my machine
But I may have found a solution. I added a additional command.aboard() even if that command is
called one cycle later from hal_action.
I pushed that to master (gmoccapy 2.2.2).
Please pull and test that one. If the work around solve the isue, I will add that too to 2.7 and 2.6 release.
Norbert
Norbert
07 Jan 2017 22:34 #85430
by thor44
Replied by thor44 on topic Gmoccapy Bug?
I also have a similar problem. I can pause the machine but if I stop the machine in mid program the machine will skip(move) to a new line sometimes several hundred lines down in the program and then stop.
How do I get gmoccapy 2.2.2? and how do I install it?
- racedirector
07 Jan 2017 23:32 - 07 Jan 2017 23:32 #85432
by racedirector
I will do that today, too hot to be in the garage today, 35C +
Replied by racedirector on topic Gmoccapy Bug?
Thanks Norbert@racedirector,
Norbert
Last edit: 07 Jan 2017 23:32 by racedirector.
08 Jan 2017 14:46 #85468
by newbynobi
We are at -9 degree celsius?
- Thank you received: 5874
08 Jan 2017 15:13 #85470
Minus 13 C here, last night went to -22.
I miss the sun..........who was complaining about to hot????? Wana trade?
Replied by tommylight on topic Gmoccapy Bug?
08 Jan 2017 15:22 #85471
by thor44
Norbert
Were are you?
It was 0 Celsius this morning here in Orem Utah and its warm today.
Were are you?
08 Jan 2017 16:43 #85474
by newbynobi
In the North of Germany, near Hannover
Norbert
Norbert
08 Jan 2017 16:46 #85475
by newbynobi
From source:
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
or use buildbot.
Norbert
From source:
or use buildbot.
Norbert
Time to create page: 0.183 seconds
