Made an error on 800x600 screen
26 Apr 2017 13:39 - 26 Apr 2017 13:39 #92144
by tecno
Made an error on 800x600 screen was created by tecno
Managed to setup full screen at start and now the gmoccapy is locked and I can no longer move screen sideways to get access to the maintenance button and fix this problem.
What line do I have to edit and how to back to basics?
Cheers
Bengt
Cheers
Bengt
Last edit: 26 Apr 2017 13:39 by tecno.
26 Apr 2017 20:07 #92167
by newbynobi
Replied by newbynobi on topic Made an error on 800x600 screen
Just delete your pref file from your config dir. With the next start that file will be created with default values.
Norbert
Norbert
26 Apr 2017 20:42 #92169
by tecno
Replied by tecno on topic Made an error on 800x600 screen
Hallo Norbert,
Sorry to say but I tried that and it will not go back to normal, any suggestion?
In INI only DISPLAY
mfg
Bengt
In INI only DISPLAY
mfg
Bengt
27 Apr 2017 07:20 #92181
Replied by cmorley on topic Made an error on 800x600 screen
hold the alt key and hold the left mouse button and then mouse scroll.
That should get the window to scroll -maybe
Chris M
Chris M
27 Apr 2017 08:05 #92182
by tecno
Sorry but I don´t have any scroll wheel on my keyboard with mousepad.
Will have to try another display but the PSU is not to be found to the one I have.
Need to do some intensive searching
Cheers
Bengt
Cheers
Bengt
27 Apr 2017 08:40 #92188
Replied by rodw on topic Made an error on 800x600 screen
Check your keyboard documentation. Some touchpads support scrolling
27 Apr 2017 08:46 #92189
by tecno
Will try to find docs, very old keyboard so I have no hopes.
Will try cmorley's in combination with the touch screen (not calibrated = no drivers installed >> next problem)
27 Apr 2017 11:14 #92193
by tecno
Have now replaced with another display as there was no way to get out from maximized window, no delete of preference file did help!
27 Apr 2017 15:15 #92219
scroll by just moving the mouse./mousepad
Cheers
Bengt
27 Apr 2017 15:39 #92220
by tecno
Did not work either, changed display so now all good in that respect.
Time to create page: 0.176 seconds
