Adding tab to signals window in gmoccapy plasma
30 Apr 2017 22:27 #92389
Adding tab to signals window in gmoccapy plasma was created by rodw
I've run out of room and want to add 1 or 2 more fields so I thought "Wouldn't be nice if I could add some tabs to one of the plasma windows?"
Changing the glade file was easy but I can't get the tabs to display correctly. The tab shown is the last one in the notepad but the signals are on the first tab.
I followed Big John's Glade tutorial and all that did was to open up a set of tabs in a brand new window so something is not right. Any help would be appreciated..
02 May 2017 19:06 #92535
by newbynobi
Replied by newbynobi on topic Adding tab to signals window in gmoccapy plasma
Hallo rodw,
please post the glade file you modified, so I can take a look.
Norbert
Norbert
02 May 2017 21:34 #92547
Replied by rodw on topic Adding tab to signals window in gmoccapy plasma
Norbert, thanks for the offer. File is attached.
- Kiddekanin
- Thank you received: 3
16 Aug 2019 07:35 #142307
by Kiddekanin
Replied by Kiddekanin on topic Adding tab to signals window in gmoccapy plasma
Got the same result trying to ad the probe tab window
Put this in .ini
EMBED_TAB_NAME = Probe
EMBED_TAB_LOCATION = box_right
EMBED_TAB_COMMAND = the probe tool file from the sim.gmoccapy folder
Put this in .ini
- Kiddekanin
16 Aug 2019 08:12 #142309
by Kiddekanin
got it working.. (facepalm) :
EMBED_TAB_COMMAND = gladevcp -x {XID} tool_probe.glade
16 Aug 2019 15:01 #142323
by newbynobi
Hallo rodw,
did you send the correct file? The file you have attached does not contain any notebook widget.
Norbert
Norbert
16 Aug 2019 15:13 #142325
Norbert, this is an old thread, you fixed that in 2017
17 Aug 2019 10:53 #142380
by newbynobi
Ups, but you see, I am willing to support and maintain gmoccapy
The following user(s) said Thank You: ikkuh
17 Aug 2019 11:24 #142384
Norbert I know this and you really do provide amazing support! I seem to recall back when the issue was first reported V 2.8 had just been released, it took a bit to get you to acknowledge there was a bug. But then I also found some bugs in Axis GUI at that time when joint axis was brand new. Linux CNC gt it right and the GUI's took a while to catchup!
But at least it was fixed promptly and we moved on. I had a similar instance this last month with an opensource platform that I had purchased a module which was not coded correctly from the every beginning. and I had to ID their bug too!
Time to create page: 0.103 seconds
