Error when launching LinuxCNC with Gmoccapy
20 Jul 2017 18:59 #96165
by nonkeldw
Error when launching LinuxCNC with Gmoccapy was created by nonkeldw
Hello
I 'have setup my machine with success. Now I want to migrate to Gmoccapy but this will not work.
I found and followed this tutorial: linuxcnc.org/docs/html/gui/gmoccapy.html
After launching LinuxCNC i got this error: "Invalid icon size 48 Self.widget.window1.show()"
What is wrong with my configuration?
Thanks!
Thanks!
20 Jul 2017 21:28 #96180
by newbynobi
Replied by newbynobi on topic Error when launching LinuxCNC with Gmoccapy
That is not an error, just a Information,
Please check for other errors, most probably a hal connection error.
Norbert
Norbert
21 Jul 2017 07:34 #96210
by nonkeldw
Replied by nonkeldw on topic Error when launching LinuxCNC with Gmoccapy
Thanks for your answer.
This is my output:
Thanks.
This is my output:
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
(gmoccapy:3883): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
/usr/bin/linuxcnc: regel 857: 3883 Geƫlimineerd $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
Thanks.
21 Jul 2017 13:06 #96218
by nonkeldw
Update:
This is my DISPLAY
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.500000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 1
PROGRAM_PREFIX = "MyPC"
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 20.000000
MAX_LINEAR_VELOCITY = 150.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
This works!
When i add LATHE = 1, then i got the error:
(gmoccapy:5228): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion `lm->priv->ids == NULL' failed
/usr/bin/linuxcnc: regel 857: 5228 Geƫlimineerd $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
This is my DISPLAY
[DISPLAY]
DISPLAY = gmoccapy
INTRO_TIME = 1
EDITOR = gedit
GEOMETRY = xyz
This works!
24 Jul 2017 16:45 #96355
by newbynobi
The problem seems to be, that you have a XYZ configuration, but a lathe is a two axis machine with just X and Z.
That may cause a error, but again, what you post as error is not the error that causes the GUI not to start.
Please check in your home directory for linuxcnc_print.txt and linuxcnc_debug.txt and post the files.
Norbert
Norbert
30 Jul 2017 15:19 #96683
by nonkeldw
30 Jul 2017 19:15 #96693
by newbynobi
Are you running debian stretch?
If you run from normal 2.7 release CD, than you have not installed Python-gstreamer
If you run actal master brunch, just pull the latest release, I fixed that a few days ago.
Norbert
Norbert
31 Jul 2017 06:59 #96723
by nonkeldw
Yes, I use debian stretch.
Is that a problem for Gmoccapy?
Thanks.
Thanks.
31 Jul 2017 07:05 #96725
No, its just you have not installed one of the prerequisites.
Replied by rodw on topic Error when launching LinuxCNC with Gmoccapy
Thanks.
31 Jul 2017 07:55 #96726
by nonkeldw
Hello
The packet "Python-gstreamer" is not available in the repository.
Time to create page: 0.099 seconds
