Error when launching LinuxCNC with Gmoccapy
02 Aug 2017 10:12 #96887
by newbynobi
Replied by newbynobi on topic Error when launching LinuxCNC with Gmoccapy
You do not need to install additional dependencies, as gmoccapy will disable sound output if that module is not installed.
But you do not use the latest release! As mentioned above, I fixed that a couple of days ago. So please pull master and run as rip-environment.
Or do you use buildbot?
Or just the CD Image?
Norbert
Norbert
08 Dec 2020 13:26 - 08 Dec 2020 13:31 #191416
by ikkuh
Replied by ikkuh on topic Error when launching LinuxCNC with Gmoccapy
same problems again in Debian Buster.
Loads of errors, the errors are not fatal though.
/usr/bin/gmoccapy:326: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
task: main loop took 0.113418 seconds
**** GMOCCAPY INFO ****
**** no audio available! ****
**** PYGST libray not installed? ****
**** is python-gstX.XX installed? ****
**** Entering init gremlin ****
Kinematics type changed
**** GMOCCAPY GETINIINFO ****
Error converting the file extensions from INI File 'FILTER','PROGRAMM_PREFIX
using as default '*.ngc'
**** virtual keyboard program found : <onboard>
14:16:32.777 WARNING Config: mousetweaks GSettings schema not found, mousetweaks integration disabled.
**** GMOCCAPY INFO: Gcode.lang found ****
(gmoccapy:2483): GtkSourceView-CRITICAL **: 14:16:33.128: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
**** GMOCCAPY INFO : inifile = /home/xx/linuxcnc/configs/mesa_2019/mesa_2019.ini ****:
**** GMOCCAPY INFO : postgui halfile = postgui.hal ****:
Jog Pin Changed
x+
Jog Button released = x+
Jog Pin Changed
x-
<snip>
3+
Jog Button released = 3+
Jog Pin Changed
3+
(onboard:2492): Gdk-CRITICAL **: 14:16:33.444: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
IDLE
(1, 2)
MANUAL Mode
RUN
IDLE
And then there has been for years this misspelling:
4 COORDINATES found = xyyz
('Fount double letter ', )
Norbert you have made a nice piece of software and I am grateful for all your troubles.
Info:
Jog Pin Changed
x+
Jog Pin Changed
x-
<snip>
3+
Jog Pin Changed
3+
IDLE
(1, 2)
MANUAL Mode
RUN
IDLE
Info:
LINUXCNC - 2.9.0-pre0-3045-g64eb1c10d
Machine configuration directory is '/home/xxx/linuxcnc/configs/mesa_2019'
Machine configuration file is 'mesa_2019.ini'
Starting LinuxCNC...
Found file(REL): ./mesa_2019.hal
Note: Using POSIX realtime
trivkins: coordinates:XYYZ
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Last edit: 08 Dec 2020 13:31 by ikkuh.
13 Mar 2022 02:26 - 13 Mar 2022 05:47 #237069
by sou528
Replied by sou528 on topic Error when launching LinuxCNC with Gmoccapy
似たような症状がありますが、アドバイスをいただけますか?最近、別のPCに新しいlinuxcncをインストールしました。(linuxcnc-2.8.2-buster.iso)これまでGmoccapyを使用していたので、とりあえず起動したばかりですが、エラーが発生します。 [attachment = 44387] linuxcnc.report.txt [/ attachment]
Last edit: 13 Mar 2022 05:47 by sou528.
- Thank you received: 5924
13 Mar 2022 02:40 #237070
Replied by tommylight on topic Error when launching LinuxCNC with Gmoccapy
What screen resolution are you using?
It is complaining about an icon size:
/usr/bin/gmoccapy:311: GtkWarning: Invalid icon size 48
The following user(s) said Thank You: sou528
13 Mar 2022 02:44 - 13 Mar 2022 02:45 #237071
by sou528
Is it the resolution of my computer monitor?
1600x900
1600x900
Last edit: 13 Mar 2022 02:45 by sou528.
13 Mar 2022 02:57 #237072
That is OK.
Might want to wait for Norbert to wake up as i can not help any further.
13 Mar 2022 03:06 #237073
by sou528
thank you.
I'll try and error while waiting for Norbert to wake up.
13 Mar 2022 09:17 #237091
by newbynobi
The only relevant error is:
Check your INI File for the Filter Section and compare with documentation for typos or other errors.
You are using master, that is the development branch, so errors are normal. I have no time at the moment to fix most of them, Fortunately Hans is doing a good job in that. May be in a half year I am able to get back to that project.
Norbert
Norbert
13 Mar 2022 11:38 - 13 Mar 2022 11:57 #237100
by sou528
thank you for your reply.I'm staring at the filter section now.It doesn't look like there's anything different.I tried the installation on another computer as well, but it gives the same error.
Last edit: 13 Mar 2022 11:57 by sou528.
13 Mar 2022 12:00 - 13 Mar 2022 12:01 #237104
by HansU
Replied by HansU on topic Error when launching LinuxCNC with Gmoccapy
Thank you Norbert!
Can you also post your HAL-files? It seems not to be a problem with the INI-file.
Last edit: 13 Mar 2022 12:01 by HansU.
Time to create page: 0.173 seconds
