Gmoccapy hangs after adding camview to hal_python_plugin.py
17 Sep 2017 10:36 #99049
by DaPeace
Hello, today i wanted to add my usb-cam to gmoccapy. Everything worked fine until i start milling.
I use a tool-probe-sensor and when i start a cnc-job its going to change-position and shows the manual tool-change-window.
When i hit the ok-button gmoccapy hangs but the system is probing and moving the axes.
Ive then removed everthing i changed and i could delimit the error to the hal_python_plugin.py.
If i add "from camview import CamView" I have that behavior..
Could someone help me?
Regards, Jan
Regards, Jan
24 Sep 2017 11:10 #99373
by newbynobi
Replied by newbynobi on topic Gmoccapy hangs after adding camview to hal_python_plugin.py
Did you start milling with live view?
What if you stop the cam bevor milling?
Norbert
Norbert
24 Sep 2017 11:57 #99375
by DaPeace
Replied by DaPeace on topic Gmoccapy hangs after adding camview to hal_python_plugin.py
Hello Norbert,
ive already opened another post in cnc-ecke.
It does not matter if i enable the view. It happens when i add the camview-line to the pythonplugins.py in gladevcp-folder.
I could leave the EMBED-Lines out of the ini-file and gmoccapy will crash too.
Time to create page: 0.097 seconds
