Ignore Limits option grayed out
24 Oct 2019 15:52 #148709
Ignore Limits option grayed out was created by Aciera
My mill uses compressed air to compensate the weight of the z-axis. After shutdown the Z-axis sits on the Limit-Home switch an I used to check the "Ignore Limits" in the jogging screen to move the axis off the switch. Now for some reason (and after quite a bit of changing other stuff in the HAL and INI) I can't check the box as it is grayed out.
Is there a setting somewhere concerning the "Ignore Limits" checkbox being active or not?
24 Oct 2019 17:28 #148717
by pl7i92
Replied by pl7i92 on topic Ignore Limits option grayed out
you need to hit F2 or get the mashine restartet to get this option visible
25 Oct 2019 10:46 #148785
Replied by Aciera on topic Ignore Limits option grayed out
Thanks for your reply.
When I try to start the machine with F2 there is a message saying the machine cannot be started because an end switch is active. I'll try to get a screen shot next time I'm in the shop.
25 Oct 2019 11:31 - 25 Oct 2019 11:36 #148786
So here we are:
The machine sits on the Z-Limit/Home switch and I cant start the machine (F2). The errors are:
"Error: Joint 2 on limit switch"
"ERROR: Can't start machine. Is there a limit switch active?"
So I have to change the HAL and set the display to "axis", comment out the gmoccapy-postgui.hal and restart LinuxCNC with axis screen and I can check the "Ignore Limits" checkbox and move the axis oft the limit switch.
Why is this not possible in my gmoccapy? This used to work (I think).
Warning: Spoiler!
# Include your custom_postgui HAL commands here
# This file will not be overwritten when you run PNCconf again
# --- User Message-Pins (Definitions in INI-File, [display]-section
#net not-aus-panel gmoccapy.messages.not-aus-panel
net modbus-error gmoccapy.messages.modbus-error
net horiz-spindel-arret gmoccapy.messages.horiz-spindel-arret
net vert-spindel-arm gmoccapy.messages.vert-spindel-arm
# ---Potentiometer Overrides
loadrt scale names=scale.spindle,scale.feed,scale.spindle-rpm
addf scale.spindle servo-thread
addf scale.feed servo-thread
addf scale.spindle-rpm servo-thread
#spindle override
setp gmoccapy.spindle-override.analog-enable TRUE
setp scale.spindle.gain 0.000977517 # MAX_SPINDLE_OVERRIDE/1023
net spindle-override-raw classicladder.0.floatout-00 => scale.spindle.in
#net spindle_poti scale.spindle.in
net spindle-override-scaled <= scale.spindle.out => gmoccapy.spindle-override.direct-value
#feed override
setp gmoccapy.feed-override.analog-enable TRUE
setp scale.feed.gain 0.000977517 # MAX_FEED_OVERRIDE/1023
net poti-feed-raw => scale.feed.in
net feed-override-scaled <= scale.feed.out => gmoccapy.feed-override.direct-value
#--- Spindle speed display
setp scale.spindle-rpm.gain -11987
net spindle-rpm-raw hm2_7i76e.0.encoder.04.velocity => scale.spindle-rpm.in
net spindle-rpm-scaled scale.spindle-rpm.out => gmoccapy.spindle_feedback_bar
#spindle override
#feed override
Last edit: 25 Oct 2019 11:36 by Aciera.
26 Oct 2019 08:45 #148818
Solved.
In gmoccapy as opposed to axis I have to go into E-Stop an out again for the "Ignore Limits" checkbox to become available.
29 Oct 2019 15:47 #149056
Replied by andypugh on topic Ignore Limits option grayed out
My mill does this, but I don't have this problem.
I think that if you activate "HOME_IGNORE_LIMITS" on the INI then the problem might go away.
(Though thinking further, it shouldn't. I will try to look in more detail at the behaviour of my machine this evening)
30 Oct 2019 12:07 #149155
by newbynobi
Replied by newbynobi on topic Ignore Limits option grayed out
@Aceira,
what release of gmoccapy do you use? See title bar or setting page.
In 3.0.8 I do not have that Behavior.
Norbert
Norbert
30 Oct 2019 18:52 #149202
Thanks Norbert for your reply. I'm still on 1.5.9!
So I guess I'll see about updating...
31 Oct 2019 22:11 #149313
by newbynobi
I will check on 1.5.9
Norbert
Norbert
02 Nov 2019 09:00 #149417
Replied by rodw on topic Ignore Limits option grayed out
I'm not sure if this would work, but I wonder if you could and2 the limit switch with the is-homing signal for that axis? That would allow you to jog off the switch before you home. That might not be quite the right signal but it might be worth exploring options like this might yield a solution.
Time to create page: 0.207 seconds
