wrong dro after start, and axis tool change window
14 Nov 2021 14:41 #226473
by DoWerna
wrong dro after start, and axis tool change window was created by DoWerna
It's about my Maho MH500,
forum.linuxcnc.org/42-deutsch/42077-maho...-plugandplay?start=0
running with linuxcnc 2.8.2 and gmoccapy.
Beforehand the machine was configured with this basic configuration.
forum.linuxcnc.org/30-cnc-machines/41442...tion?start=20#204531
so started with Axis, and then only changed to gmoccapy in the configuration.
What I noticed now is that after the homing the wrong DRO is displayed first
G58 is displayed, but with the machine coordinates on the right. If I really want to see g58, for example, I must first call a g57 and back again aug G58, then the DRO output is also correct.
Have googled , on github I have found exactly such an issue from 2016.
github.com/LinuxCNC/linuxcnc/issues/157
The next thing would be the tool change.
works fine , but with the axis window.
Probably because my configuration was only changed to gmoccapy, from axis.
Afterwards I have to look again at the connections in the Hal and compare them with a gmoccapy example
but at least with the DRO story I'm quite at a loss
My configuration folder is on github
github.com/DoWerna/maho_retrofit/blob/master/basic7i97.hal
github.com/DoWerna/maho_retrofit/blob/master/basic7i97.ini
github.com/DoWerna/maho_retrofit/blob/master/custom_postgui.hal
and the entire folder
15 Nov 2021 12:16 #226571
by DoWerna
Replied by DoWerna on topic wrong dro after start, and axis tool change window
Just test renamed the .var .pref files and restarted the machine.
Unfortunately without success the DRO still shows the wrong values at startup.
Only when I run a G55 and G54 the G54 values are displayed.
15 Nov 2021 12:50 #226575
by MaHa
Replied by MaHa on topic wrong dro after start, and axis tool change window
Did you try in [RS274NGC] section to enter a startup code with the desired UCS
RS274NGC_STARTUP_CODE = G0 G17 G21 G40 G49 G55 G80 G90 G92.1 G94 M48
The following user(s) said Thank You: DoWerna
15 Nov 2021 16:05 #226586
by DoWerna
Yes
I have just inserted the line.
but has unfortunately brought nothing.
After homing, the Abs coordinates are always displayed in the DRO, although the values in the DRO are labeled with G55.
to see the real G55 values you need a G54 and then G55
15 Nov 2021 22:36 #226606
by DoWerna
in the githubissue the problem was solved by recompiling everything.
What I have done so far
sudo apt remove linuxcnc-uspace
sudo apt autoremove
sudo apt install linuxcnc-uspace
so linuxcnc including dependencies deleted and reinstalled.
This has brought nothing
Possibly it has similar reasons with me,
I started the machine configuration with 2.9 from the buildbot, my 7i97 was not supported by 2.8.
have then later changed to the stable 2.8.2...
Translated with www.DeepL.com/Translator (free version)
sudo apt autoremove
16 Nov 2021 12:28 #226649
by DoWerna
wiped through a bit again
sudo apt purge linuxcnc-uspace
sudo apt --purge autoremove
sudo apt purge mesaflash
sudo apt update
sudo apt dist-upgrade
sudo apt install linuxcnc-uspace-dev
sudo apt install mesaflash
Now it seems to work
sudo apt update
16 Nov 2021 15:55 - 16 Nov 2021 17:18 #226658
by DoWerna
apparently not after all
after the reinstallation everything worked.
after homing were always immediately displayed the correct values in the DRO.
Have now switched to the Gmoccapy Toolchange window...
I have really only edited the configuration files and started some previus configs for testing
now shows me after the homing again the machine constants, instead of the selected G5X coordinate system.
Last edit: 16 Nov 2021 17:18 by DoWerna.
22 Nov 2021 07:55 #227277
by DoWerna
Am I really the only one with this "problem"?
Of course, this is not really a big deal now.
You only have to call up the coordinate system again and the values are correct.
I would find it only strange that with me a bug occurs, which has no one else.
Means for me that I have somewhere an error in the configuration or installation....
22 Nov 2021 10:10 #227287
by newbynobi
Replied by newbynobi on topic wrong dro after start, and axis tool change window
I do not see any error in INI or hal files. It is very strange, that your machine starts with G58.
Actually I have no time to get deeper into this, but I will have it on my to Do list.
What hapens if you start a sim config?
Norbert
Norbert
22 Nov 2021 23:51 #227341
Replied by andypugh on topic wrong dro after start, and axis tool change window
Maybe delete the linuxcnc.var file? Possibly that has an accidental persistent entry.
Time to create page: 0.123 seconds
