Translate offsetpage.glade.h - dont work
30 Jun 2022 20:26 #246305
by zz912
Translate offsetpage.glade.h - dont work was created by zz912
I work on translate to czech, but I cant translate stuff in offset page:
src/po/gmoccapy/cs.po - it looks good, but it is not working too
I tried espanol:
src/po/gmoccapy/es.po - it is wierd "../../../"
#: ../lib/python/gladevcp/offsetpage.glade.h:27
msgid "Offset Name"
msgstr "Pojmenování"
I tried espanol:
#: ../../../../lib/python/gladevcp/offsetpage.glade.h:27
msgid "Offset Name"
msgstr "Nombre offset"
02 Jul 2022 01:24 #246408
Replied by andypugh on topic Translate offsetpage.glade.h - dont work
github.com/LinuxCNC/linuxcnc/blob/master...ffsetpage.glade#L416
It claims to be translatable. Offset doesn't get translated, so I would assume that nothing else in that file is either. (Maybe you could look?)
Possibly the file needs adding to the "files to translate" list. I am rather fuzzy on how that works.
02 Jul 2022 12:11 #246434
by zz912
This?
I'd do anything to fix LCNC, but I'm not a programmer. I couldn't find anywhere how translations with *.po work. There are a bunch of articles about translating *.po files. But nowhere is it explained how pot files are created, and what the compiled *.mo files do.
Replied by zz912 on topic Translate offsetpage.glade.h - dont work
I don't know what to look at.Maybe you could look?
This?
cs.po
#: ../lib/python/gladevcp/offsetpage.glade.h:26
msgid "Offset"
msgstr ""
"Souřadný\n"
"systém"
02 Jul 2022 18:52 #246456
It's rather odd as it seems that other things are being translated, just not the column headers.
Are you rebuilding LinuxCNC after making your changes? I think you need to?
If you are translating LinuxCNC, it might be best to do it in Weblate. (Or is that how you are doing it?)
02 Jul 2022 20:24 #246465
Something that I am puzzled by is the offsetpage.glade.h thing? That .h looks wrong. (but don't see it in the files that I have)
Incidentally, are you working in Weblate or manually editing the .po?
hosted.weblate.org/projects/linuxcnc/linuxcnc/
I assume the former, as Czech is not on the list.
I suggest making a pull-request and then switching to Weblate, it's a better interface and is generally a case of just running your eyes over an automatic translation.
02 Jul 2022 20:33 - 03 Jul 2022 10:39 #246466
by zz912
looks like you are right
Edit: This picture is wrong. Gmoccapy has own Zero G92 button. offsetpage.glade.h has own Zero G92 button.
Yes
Can weblate be used for version 2.8?
I use Poedit
Yes
I use Poedit
Last edit: 03 Jul 2022 10:39 by zz912.
02 Jul 2022 20:57 #246468
by zz912
look at:
github.com/LinuxCNC/linuxcnc/blob/2.8/src/po/Submakefile
header and *.pot file is made by "make" ,Something that I am puzzled by is the offsetpage.glade.h thing? That .h looks wrong. (but don't see it in the files that I have)
look at:
02 Jul 2022 21:06 #246469
Good point. Probably not at the moment.Can weblate be used for version 2.8?
02 Jul 2022 21:22 #246470
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...gmoccapy/es.po#L1965
But in 2.9 the reference is not there.
Are you editing src/po/gmoccapy/cs.po or src/po/cs.po?
Looking again at the es.po example, we have (in src/po/es.po, in the master branch)
github.com/LinuxCNC/linuxcnc/blob/master/src/po/es.po#L20012
So my guess is that the references in gmoccapy/po to generic glade (rather than gmoccapy) files are wrong,
Perhaps try copying them in to src/po and removing the .h and seeing what happens?
I see reference to offsetpage.glade.h in 2.8:
look at:
03 Jul 2022 06:39 #246479
by zz912
I have only src/po/gmoccapy/cs.po
src/po/cs.pro dont exist now
Time to create page: 0.235 seconds
