Question: Gmoccapy 3.4.2 and touchscreen
21 Feb 2023 19:44 #264979
by 0x2102
Question: Gmoccapy 3.4.2 and touchscreen was created by 0x2102
Hello,
I recently set up a test system with Debian 11 and LinuxCNC 2.9. In Gmoccapy 3.4.2 I noticed two things in regards to my touchscreen:
1.) I am no longer able to drag the wireframe in Preview. Move it to the left/right or up/down. Mouse works, but not the touchscreen.
2.) In order to set XYZ to a certain value or 0 I would normally touch the Axis letter (X / Y / Z) and enter the value. This works on and off.
It works better when I click / touch right next to the actual Axis letter.
Has anybody else noticed this, too? I have tested Axis, QT Dragon, Probe Basic etc, and there I am able to use my touchscreen to move things in Preview.
Thanks.
-Markus
Thanks.
-Markus
22 Feb 2023 06:14 #265012
by newbynobi
Replied by newbynobi on topic Question: Gmoccapy 3.4.2 and touchscreen
Hallo
Ich the preview stuff works with a normal mouse, than I guess it is a touch screen problem. On mine I needed to configure the behavior of the right mouse button.
The DRO hast two areas to react to clicks! If you click on the axis letter, you should get the input screen to enter axis values. If you click in the number area, the DRO will toggle DRO_Absolut ; DRO relative ; DRO distance to go.
Norbert
Norbert
22 Feb 2023 17:46 #265047
by 0x2102
Replied by 0x2102 on topic Question: Gmoccapy 3.4.2 and touchscreen
Hi Norbert,
thanks for getting back to me. What's odd is that is works fine in Axis or any other GUI, just not in Gmoccapy. When you try to drag in Gmoccapy it moves the wireframe 1mm each time. Is there a difference in Axis vs Gmoccapy when it comes to the Preview screen?
Regards,
-Markus
Regards,
-Markus
22 Feb 2023 20:27 #265065
by HansU
Replied by HansU on topic Question: Gmoccapy 3.4.2 and touchscreen
Can you connect a mouse and try the behavior with that? Like Norbert said, I also can't see a difference in behavior between Axis and Gmoccapy using a mouse.
22 Feb 2023 20:32 #265066
by 0x2102
Mouse works with both Axis and Gmoccapy.
This is a test system with LCNC 2.9 / Debian 11 and latest Gmoccapy. When I switch back to Debian 10 / LCNC 2.8 and Gmoccapy 3.1.x - it works fine there as well.
Do you have a touchscreen? Is is working for you?
23 Feb 2023 08:06 #265112
by HansU
I have a touchscree, but currently not in my vicinity.
It would be interesting to know if it works with Debian 10 and LCNC 2.9 to exclude that is not a driver issue.
23 Feb 2023 21:56 - 23 Feb 2023 21:56 #265156
by 0x2102
The problem is with Gmoccapy 3.4.2.
I have installed a fresh copy of LinuxCNC ISO with 2.8.4 - did a test and then upgraded to 2.10 (master).
On 2.8.4 it's working fine, but not on 2.9/2.10 with Gmoccapy 3.4.2
Last edit: 23 Feb 2023 21:56 by 0x2102.
24 Feb 2023 19:23 #265267
by HansU
Thanks for your testing. I have actually no idea right now. I created an issue here: github.com/LinuxCNC/linuxcnc/issues/2361
The following user(s) said Thank You: Funny
07 Oct 2023 23:22 #282522
by newbynobi
I am trying to solve the problem, unfortunately I am not at home and got no touch scrren here.
Could you try:
- Go to settings page
- select mouse button mode (the 5. entry should be the active one)
- change the settings from the 5.entry to the 3. one
- Try to move the preview around
IMHO that is the entry axis is using
Report back.
Norbert
Could you try:
Report back.
Norbert
13 Oct 2023 19:15 #282933
by 0x2102
Hi Norbert,
I just tried that but it didn't made a difference. Same problem.
Regards,
Markus
Regards,
Markus
Time to create page: 0.207 seconds
