Turning
02 Sep 2013 18:10 #38418
by BigJohnT
This is my OD turning subroutine for ngcgui.
JT
(info: OD Turning)
o<od> sub
#<material-dia> = #1 (=0.750 Start Diameter)
#<final_dia> = #2 (=0.700 Finish Diameter)
#<rough-doc> = #3 (=0.020 Roughing DOC)
#<final-doc> = #4 (=0.010 Finish DOC)
#<surface-speed> = #5 (=100 Surface Speed)
#<rough-feed> = #6 (=2 Rough Feed)
#<finish-feed> = #7 (=1 Finish Feed)
#<max_rpm> = #8 (=1500 Max RPM)
#<z-end> = #9 (=-0.5 End of Cut)
#<z-start> = #10 (=0.100 Start of Cut)
#<rough-tool> = #11 (=1 Roughing Tool)
#<finish-tool> = #12 (=1 Finishing Tool)
#<coolant> = #13 (=8 Flood=8, Off=9)
#<roughing> = 0
G7 G96 D#<max_rpm> S#<surface-speed>
; Rough the OD if needed
o100 if [[#<material-dia> - #<final_dia>]/2 GT #<final-doc>]
#<roughing> = 1
#<rough-diam> = [#<final_dia> + [#<final-doc> * 2]]
#<rough-passes> = FUP[[[[#<material-dia> - #<rough-diam>]/2]/#<rough-doc>]]
#<rough-cut> = [[#<material-dia> - #<rough-diam>]/#<rough-passes>]
T#<rough-tool> M6 G43
M3 M#<coolant>
G0 X#<material-dia> Z#<z-start>
#1=#<material-dia>
F#<rough-feed>
o110 repeat[#<rough-passes>]
#1 = [#1 - #<rough-cut>]
X#1
G1 Z#<z-end>
X[#1 + #<rough-cut> + 0.025]
G0 Z#<z-start>
o110 endrepeat
M9
o100 endif
o120 if [#<roughing> EQ 1]
o130 if [#<rough-tool> NE #<finish-tool>]
(msg,rough)
T#<finish-tool> M6 G43
o130 endif
o120 else
(msg,no rough)
o120 endif
;Final Cut
M3 M#<coolant>
F#<finish-feed>
#1 = #<final_dia>
G0 X#1 Z#<z-start>
G1 Z#<z-end>
X[#<material-dia> + 0.025]
G0 Z#<z-start>
G0 X[#1+0.025]
M5 M9
Z#<z-start>
G97
G53 G0 X0 Z0
o<od> endsub
JT
The following user(s) said Thank You: cjlear
Time to create page: 0.057 seconds
