Peck Grooving
02 Sep 2013 23:02 - 02 Sep 2013 23:03 #38431
by ArcEye
Peck Grooving was created by ArcEye
Here's an esoteric one for you.
Written for cncbasher to help him machine heat sink fins into aluminium extruder housings, it is a grooving sub with optional, programmable pecking to clear swarf.
You can have a full withdrawal or a partial chip breaking withdrawal and the depth at which pecking begins plus percentage feed deceases, speed increases etc are programmable.
;; Notes
;; peck grooving on X axis
;; ArcEye 2013
(info: Metric Lathe - stand alone adjustable peck grooving - multiple grooves - all values positive, will be converted)
o<peck_groove> sub
#<_move_feed> = #1 (=175 linear feed)
#<_groove_feed> = #2 (=50 groove feed )
#<_spindle_speed> = #3 (=800 spindle speed)
#<_depth> = #4 (=10 depth grooves)
#<_groove_width> = #5 (=5 groove tool width)
#<_grooves> = #6 (=1 grooves)
#<_billet_diameter> = #7 (=30 billet diameter)
#<_Z_start>= #8 (=5 location Z groove 1)
#<_Z_groove_increment> =#9 (=10 Z inc. between grooves)
#<_X_standoff> = #10 (=35 X start and finish)
#<_X_safe> = #11 (=2 X between grooves & retract)
#<_coolant> = #12 (=9 coolant 7=Mist 8=Flood 9=Off)
#<_pecking> = #13 (=1 Peck 0 = No 1 = Yes)
#<_peck_start> = #14 (=2 start pecking, N x groove width)
#<_retraction_model> = #15 (=0 Retract 0=full 1=groove dia)
#<_pause> =#16 (=4 Pause at top of retraction)
#<_feed_reduction_ratio> = #17 (=0.90 feed reduction ratio)
#<_speed_increase_ratio> = #18 (=1.2 speed increase ratio)
#<_peck_ratio> = #19 (=0.90 peck reduction ratio)
#<_min_feed> = #20 (=10 min feed)
#<_max_speed> = #21 (=1000 max speed)
#<_min_peck> = #22 (=0.50 min peck fraction of groove width)
#<X_end> = [#<_billet_diameter> - [#<_depth> * 2]]
#<NoPeckDepth> = [#<_billet_diameter> -[#<_groove_width> * #<_peck_start>]]
o200 if[ #<NoPeckDepth> LE #<X_end>]
#<_pecking> = 0
(debug, Pecking turned off)
o200 endif
#<GrooveNum> = 1
#<X> = [#<_billet_diameter> + #<_X_safe>]
#<Z> = -#<_Z_start>
o202 if[ #<_pecking> EQ 1 ]
#<X> = #<NoPeckDepth>
o201 if[ #<NoPeckDepth> LT #<X_end> ]
#<X> = #<X_end>
o201 endif
o202 else
#<X> = #<X_end>
o202 endif
#<F> = #<_groove_feed>
#<S> = #<_spindle_speed>
#<Peck> = #<_groove_width>
#<MinPeck> = [#<Peck> * #<_min_peck> ]
#<OldX> = #<X>
G17 G21 G40 G49 G7
G80
G90
G64 P0.1
F#<_move_feed> S#<_spindle_speed>
M3
M#<_coolant>
G00 X#<_X_standoff> Z#<_Z_start>
o101 while[#<GrooveNum> LE #<_grooves> ]
G00 X[#<_X_safe> + #<_billet_diameter>] Z#<Z>
G00 X[#<_billet_diameter> +0.1]
G01 X#<X> F#<F>
o124 if[#<_pecking> EQ 1]
o102 if[ #<_retraction_model> EQ 0]
G00 X[#<_billet_diameter> + #<_X_safe>]
o102 else
G00 X [#<X> + #<_groove_width> ]
o102 endif
o112 if[#<X> GT #<X_end> ] ;; prevent pause at end of groove
G4 P#<_pause>
o112 endif
o124 endif
o103 while[#<X> GT #<X_end> ]
o110 if[ #<_pecking> EQ 1 ]
#<OldX> = #<X>
G00 X[#<OldX> +0.5]
#<Peck> = [#<Peck> * #<_peck_ratio>]
o104 if[#<Peck> LT #<MinPeck> ]
#<Peck> = #<MinPeck>
o104 endif
#<F> = [#<F> * #<_feed_reduction_ratio>]
o105 if[#<F> LT #<_min_feed> ]
#<F> = #<_min_feed>
o105 endif
#<S> = [#<S> * #<_speed_increase_ratio>]
o106 if[#<S> GT #<_max_speed> ]
#<S> = #<_max_speed>
o106 endif
#<X> = [#<X> - #<Peck>]
o107 if[ #<X> LT #<X_end>]
#<X> = #<X_end>
o107 endif
S#<S>
o110 endif
G01 X#<X> F#<F>
o109 if[ #<_pecking> EQ 1 ]
o108 if[ #<_retraction_model> EQ 0]
o108 else
o108 endif
o111 if[#<X> GT #<X_end>] ;; prevent pause at end of groove
G4 P#<_pause>
o111 endif
o109 endif
o103 endwhile
o113 if[ #<_pecking> EQ 1 ]
o114 if[ #<NoPeckDepth> LT #<X_end> ]
#<X> = #<X_end>
o114 endif
o113 else
#<X> = #<X_end>
o113 endif
#<Z> = [#<Z> - #<_Z_groove_increment>]
#<GrooveNum> = [#<GrooveNum> + 1]
o101 endwhile
M9
M5
G00 X#<_X_standoff> Z-#<_Z_start>
M2
o<peck_groove> endsub
Last edit: 02 Sep 2013 23:03 by ArcEye.
Time to create page: 0.083 seconds
