face_lathe3
04 Sep 2013 14:49 #38461
by Rick G
face_lathe3 was created by Rick G
Here is a facing sub for the lathe that allows you to select the start and finish diameter of the facing as well as the start and finish depth.
For simple lathe without tool offsets, tool change, etc.
Rick G
;face_lathe3 for lathe
;face cut for lathe from Start Diameter to Finish Diameter
;UNTESTED concept only, edit and test for your own use before using
;Before running make sure tool is in a position that it can safely travel to Z start then X Start Diam.
o<face_lathe3>sub
#<Start_Diam> = #1 (=1.00 Large Diameter)
#<Finish_Diam> = #2 (=0.625 Small Diameter)
#<Max_Cut> = #3 (=0.005 Max Depth of Cut)
#<Start_z> = #4 (=0.00 Z Start of Cut)
#<End_z> = #5 (=-0.025 Z End of Cut)
#<Feed> = #6 (=4 Feed IPM)
#<RPM> = #7 (=500 RPM)
#<Final_Cut> = #8 (=.002 Final Cut)
#<Fin_ Feed> = #9 (=2 Final cut speed IPM)
#<Spring_Cuts> = #10 (=1 Spring Cuts)
#<Z_Len> = [ #<Start_z> - [#<End_z> + #<Final_Cut>]] ; calculate total Z depth
#<Cuts> = FUP [[#<Z_Len> / #<Max_Cut>]] ; round up the number of passes to reach total Z depth
#<Z_Cut> = [#<Z_Len> / #<Cuts>] ; depth of each Z cut
G18 (xz plane)
G20 (inches)
G40 (cancel cutter radius compensation)
G49 (cancel tool length offset)
G90 (absolute distance mode)
G94 (units/min feed rate)
G7 (diameter mode)
G64 p.001 q.001 (set path tolerance)
; if Z End of Cut is greater than Z Start of Cut do not run
o201 if [#<End_z> gt #<Start_z>]
(debug, Z End of Cut #<End_z># greater than Z Start of Cut #<Start_z>)
o200 return
o201 endif
F#<Feed>
S#<RPM>
M3 ; spindle on cw
G4 P1 ; pause for spindle to reach RPM
G0 Z[#<Start_z> + .010]
G0 X #<Start_Diam>
G1 Z#<Start_z>
#<Z_Target> = #<Start_z>
o100 while [#<Cuts> gt 0]
#<Z_Target> = [#<Z_Target> - #<Z_Cut>]
G0 X #<Start_Diam> ; X to cut position
G0 Z [#<Z_Target> + .010]
G1 Z #<Z_Target>
G1 X #<Finish_Diam> ; Cut face
#<Cuts> = [#<Cuts> - 1]
o100 endwhile
; finish cut
F#<Fin_ Feed>
G0 Z [#<End_z> + .010]
G1 Z #<End_z>
;Spring cuts
o102 while [#<Spring_Cuts> gt 0]
G1 Z #<End_z>
#<Spring_Cuts> = [#<Spring_Cuts> -1]
o102 endwhile
M5 ;stop spindle
G0 X#<Start_Diam> Z #<Start_z>
o<face_lathe3>endsub
Rick G
04 Sep 2013 21:27 #38469
My subs (with pretty GUI) include a taper angle for turning, boring and facing too:
www.linuxcnc.org/index.php/english/forum...s/26550-lathe-macros
Less convenient to call from MDI though, so they would need editing for that usage model.
Replied by andypugh on topic face_lathe3
Time to create page: 0.740 seconds
