Tormach PathPilot lathe tool setup GUI
22 Dec 2015 20:50 - 22 Dec 2015 20:53 #67246
by Muzzer
Replied by Muzzer on topic Tormach PathPilot lathe tool setup GUI
Just for reference, the DVD is actually a disk image, not an install / setup disk. It's an image of the installation, made with r-image. To create an installation, you need a fresh HDD/SSD. I haven't done it myself but I understand it can be done.
And I might be wrong but it doesn't seem to appreciate being transferred to a USB Flash Drive (UFD) - needs to be burned to a bootable DVD.
Last edit: 22 Dec 2015 20:53 by Muzzer. Reason: Missed a bit
22 Dec 2015 21:55 #67247
by lincamx
Replied by lincamx on topic Tormach PathPilot lathe tool setup GUI
you are on the $$$$, This has been my experience.
23 Dec 2015 10:05 #67261
by cncbasher
Replied by cncbasher on topic Tormach PathPilot lathe tool setup GUI
using r-image works fine
03 Dec 2021 05:50 #228259
by nkp
do they have something similar now?
Replied by nkp on topic Tormach PathPilot lathe tool setup GUI
they charge $10 for the code and $28 for posting the cd
13 Dec 2021 15:00 #229010
by gerritv
Replied by gerritv on topic Tormach PathPilot lathe tool setup GUI
You should probably contact Tormach directly, where you will be told that yes indeed that is 'still the way'
The install USB is likely extra. You don't need the source code to modify the GUI, for that you only need the install disk.
04 Jan 2022 05:06 #230716
by smgvbest
Replied by smgvbest on topic Tormach PathPilot lathe tool setup GUI
Which version of PP are you talking about
V2 is on a USB Stick for 24.95
Source code is $10 shipped.
Source code is just PP source, it will not build PP for you. you need to get LinuxCNC. add RT Kernel etc to get a working version from source.
I found it easier to do get the USB stick and source then install both to make a dev machine that I run on-top of VMware. PP doesn't support VMware but a simple change fixes that. it just makes sure if PP is virtualized it runs in SIM mode is all
14 Jan 2022 17:57 #231784
by porshe
Replied by porshe on topic Tormach PathPilot lathe tool setup GUI
How do they buy the source code of PP v2? USB stick PP 2.3.6
I have.
I have.
14 Jan 2022 23:53 #231822
by smgvbest
For source code just use thier contact us page and ask for it. They’ll reply with what to do which is usually send check for $10 payable to xxxxx then they send it to you once the get it.
Moderators: cncbasher
Time to create page: 0.079 seconds
