Stepper motor scale adjustment
- remartinez
28 Nov 2015 19:32 #65966
by remartinez
Stepper motor scale adjustment was created by remartinez
Is there a simple way or trick of calculating and adjusting the stepper motor scale in Pathpilot?
Thanks to everyone for helping me out,
Raul
Raul
28 Nov 2015 19:52 #65968
Replied by PCW on topic Stepper motor scale adjustment
How this is set depends on your hal and ini file setup, with your previously posted files these are set in the ini file:
(in the axis 0 section for example)
SCALE = -8017
This number (-8017) represents the number for steps per machine unit (inches in this case)
so you need to calculate the number of steps per machine unit for your mechanics/stepdrive-settings
For direct drive step motor systems this would normally be 200*ustep*leadscrew turns-per-inch
(ustep is the number of usteps per full step so would be 4 for 1/4 step driver setting etc)
The sign of the scale (-8017 currently) changes the motion direction
SCALE = -8017
Moderators: cncbasher
Time to create page: 0.199 seconds
