Pathpilot install
03 Mar 2016 09:00 #70953
by tkamsker
Pathpilot install was created by tkamsker
Hi i wnat to play around and see all the magic of the path pilot ui .
So i bought the restore cd and tried to install on an GA board which i bought for that playing around
it has SSD disk and external DVD drive
But it boots does play around show me the screen for installing then it works a long time and errors by image is missing
what can that be ? does it have to be an "internal" dvd drive ?
is there a way to install path pilot from an hard disk ? or usb stick ?
any hints are welcome thomas
- balestrino
03 Mar 2016 09:29 #70955
by balestrino
Replied by balestrino on topic Pathpilot install
same happened to me, install error message if SSD was present
no problem with SATA disk
03 Mar 2016 13:37 #70965
by cncbasher
Replied by cncbasher on topic Pathpilot install
what is the exact error message ?
03 Mar 2016 17:39 #70983
by tkamsker
Replied by tkamsker on topic Pathpilot install
hi
i tried an SSD machine and one sata machine
on the SSD it complained about to less space (it only has 30gb ) and rimage is using 2 of them then it is to small !!!
So i changed to my dev machine it starts all well showing the us keyboard shows normal linux loading stuff shows the x cursor
but then it says image not found
04 Mar 2016 11:38 #71017
by cncbasher
the r-image expects a drive of 260gig for pathpilot , it can be re-imaged if thats the word to fit to others if you use the r-image software , i often use 80gig drives without problem . ssd's are a little different and also require a few changes to stop the drive
endlessly re-writing to the ssd which will be bad , theres many post on the internet on how to correctly set up an ssd for debian & ubuntu ( pathpilot uses ubuntu ) .
04 Mar 2016 14:32 #71032
by tkamsker
ah i see that is an worthy information
so i think i now go and get an disk bigger or equal 260 gig get me an SATA dvd drive and see if i can start from there and because i want to do parallel or General mechatronics card do you think it will be able to install without an mesa card present ? Then i go and buy an mesa card as well -
thx
thomas
thx
thomas
04 Mar 2016 15:32 - 04 Mar 2016 15:32 #71037
by geoffs
Replied by geoffs on topic Pathpilot install
It will install just fine without a Mesa card. I installed it on an old PC and on a virtual machine under VMware.
It will complain of course when it tries to start PP but pressing the left ALT and SHIFT keys will let you into Debian to change the config.
Last edit: 04 Mar 2016 15:32 by geoffs.
04 Mar 2016 15:59 #71044
by cncbasher
Thomas.
i'm not sure if the GM driver is present in pathpilot , i'm not at a machine at the moment to check , but i can easily add it for you if needed , if you follow the tutorial help information at the top of this forum , it will show you how to bypass the mesa checks
either temporally or remove them completely , although their are a few files to modify .
email me directly if you require help .
The following user(s) said Thank You: tkamsker
07 Mar 2016 09:33 #71143
by tkamsker
after buing an non sad disk and internal dvd drive i got it installed ,..
cncbasher thank you very much m really
i decided to get me an mesa card and see the whole setup.
i spend yesterday some time on the configs and understand how they integrated all that to their machines , .
my plan is simply put that controller to one of our machines (and our machines are really verry comparable to the 1100 and lathe but made in austria/europe !!) so just minimal adjustments and it will run. But then i´ll do some parts with it (the tool changer parts for instances ) and then i can from dayli work compare if it is worth the effort. but really it is an nice ui
Moderators: cncbasher
Time to create page: 0.165 seconds
