PathPilot and Modbus
03 Apr 2016 14:04 #72625
by smgvbest
PathPilot and Modbus was created by smgvbest
Has anyone worked on getting a MODBUS devices working with PathPilot, example VFS Spindles? or PLC's for Digital In/Out?
Wondering what would be entailed in doing so?
my best guess is getting full linuxcnc ~2.6.3 compiling. but then can you just copy the modules to /home/operator/tmc/bin and/or lib and use them?
TIA
Sandra
TIA
Sandra
03 Apr 2016 17:51 #72636
by cncbasher
Replied by cncbasher on topic PathPilot and Modbus
as far as i can see looking at the sources Modbus is installed , so you should not have any problems
just treat it exactly the same as Linuxcnc .
03 Apr 2016 20:57 #72652
by smgvbest
Replied by smgvbest on topic PathPilot and Modbus
Thank you
I did try it and added to my tormach_lathe_sim.hal
loadusr -W mb2hal config=mb2hal.ini
with jsut a default sample config
Immediately got a error. checking the log I say mb2hal not found
went to the sources directory and cp mb2hal ~/tmc/bin
Rebooted, quicker actually
Came up ok this time except excessive logging so tweaked the debug settings in the sample (doesn't actually have anything it's connecting to at this point)
and I can see the hal variables showing up
now to make it work
I do want to write a custom VFD Driver for the Teco EV101 but figure using mb2hal would be quickest way to get a spindle going.
also have some Modbus Relays to use which for mb2hal should be simple to implement.
Loaded HAL Components:
ID Type Name PID State
30 User halcmd2687 2687 ready
34 RT milljogtranslator ready
33 User shuttlexpress4 2682 ready
31 RT time ready
28 User tormach 2672 ready
26 User inihal 2671 ready
25 RT near ready
24 RT scale ready
23 RT lowpass ready
22 RT limit2 ready
21 RT sim_encoder ready
20 RT encoder ready
>> 19 User mb2hal 2657 ready
17 User usbio 2656 ready
15 RT not ready
14 RT tormachltc ready
13 RT pwmgen ready
12 RT abs ready
11 RT estop_latch ready
10 RT stepgen ready
9 RT motmod ready
8 RT trivkins ready
7 User halui 2644 ready
5 User iocontrol 2642 ready
19 float OUT 0 mb2hal.XDrive01.00.float
19 s32 OUT 0 mb2hal.XDrive01.00.int
19 float OUT 0 mb2hal.XDrive01.01.float
19 s32 OUT 0 mb2hal.XDrive01.01.int
19 u32 OUT 0x00000000 mb2hal.XDrive01.num_errors
now to make it work
- racedirector
- Thank you received: 41
04 Apr 2016 10:35 #72693
by racedirector
Replied by racedirector on topic PathPilot and Modbus
I had to install libmodbus on my PathPilot install to get mb2hal to work properly. I'll go out and check what version I installed. Yes, mb2hal had to be in ~/tmc/bin as you found out. I run an Hitachi X200 VFD via mb2hal so it is possible.
04 Apr 2016 11:19 #72697
by Swapper
Replied by Swapper on topic PathPilot and Modbus
racedirector any chance you can share the config for the Hitachi X200 VFD ?
- racedirector
05 Apr 2016 00:51 - 05 Apr 2016 00:59 #72755
by racedirector
No problem, attached.
Used like this:
I don't currently use all the definitions in the ini yet, got sidetracked getting PathPilot working
This line connects the spindle speed to the PathPilot display. Took me a while to figure that one out!
Cheers
Used like this:
# Blacksheep Woodworks Addition for x200 VFD
loadusr -Wn x200 mb2hal config=x200vfd.ini
loadrt scale count=1
addf scale.0 servo-thread
setp scale.0.gain .16666667
net spindle-speed-out scale.0.in motion.spindle-speed-out tormach.spindle-speed-out
net x200-freq x200.frequency.00 <= scale.0.out
net x200-run x200.run.00 <= motion.spindle-on
net spindle-at-speed x200.at-speed.00 <= motion.spindle-at-speed
setp x200.direction.00 0
Cheers
Last edit: 05 Apr 2016 00:59 by racedirector. Reason: Added PathPilot specifics
10 Apr 2016 00:08 #73017
by smgvbest
Cool, Thank you for the information, I'm still setting things up on the Lathe Side. got the PathPilot PC running.
Will try running the pncconf for the mesa card and get the steppers working first, then then work on the spindle.
Good to know I can get the spindle working and my relays should follow with no problems, or so I hope.
Moderators: cncbasher
Time to create page: 0.138 seconds
