PathPilot: VFD selection
02 May 2016 09:59 #74125
by cncbasher
Replied by cncbasher on topic PathPilot: VFD selection
just call me if you need a configuration for Pathpilot , to suit your machine , if your stuck
i would start by just looking at a configuration for linuxcnc first to suit your machine , and get to understand that first ,
this will give you a good starting point and a sound base of understanding , then look at pathpilot , with little changes the same
config will work with both linuxcnc & pathpilot .
The following user(s) said Thank You: tomdchi
02 May 2016 12:48 #74139
by tomdchi
Replied by tomdchi on topic PathPilot: VFD selection
Thanks very much! I have my controller "PC" set up and the LinuxCNC ISO booting off a USB stick, so once I've got the CNC conversion of the mill underway, I'll get standard LinuxCNC working and then work on PathPilot.
Moderators: cncbasher
Time to create page: 0.058 seconds
