PCNC770 4th Axis w/ Clear Path Servo & PathPilot
- charliebrumfield
03 Jun 2016 03:59 #75382
by charliebrumfield
Replied by charliebrumfield on topic PCNC770 4th Axis w/ Clear Path Servo & PathPilot
set max_error = 0 still getting a joint following error. which I could have sworn wasn't possible as I though setting max_error = 0 effectively turns off the error checking for that axis... ugh I could be wrong. it's late and this project has my brain fried...
03 Jun 2016 04:44 - 03 Jun 2016 04:56 #75383
Replied by PCW on topic PCNC770 4th Axis w/ Clear Path Servo & PathPilot
Setting MAX_ERROR to 0 in the ini file turns off error bounding in the PID component
So its not at all clear whats wrong (I cannot duplicate this issue with similar settings), I'm beginning to wonder if this isn't a hardware issue. What card type to you have in your Tormach controller, 5I25 or 6I25?
Last edit: 03 Jun 2016 04:56 by PCW.
The following user(s) said Thank You: charliebrumfield
03 Jun 2016 09:19 #75392
Replied by andypugh on topic PCNC770 4th Axis w/ Clear Path Servo & PathPilot
Is LinuxCNC working in stepgen feedback or encoder feedback?
- charliebrumfield
03 Jun 2016 14:39 - 03 Jun 2016 15:17 #75432
by charliebrumfield
5i25 as far as I know. at least that's what the hal file says.
this is the upgrade kit I snagged from tormach. the tormach controller I upgraded uses the PCIe card option
www.tormach.com/store/index.php?app=ecom...ow&ref=PP770-UPGRADE
Last edit: 03 Jun 2016 15:17 by charliebrumfield. Reason: added link to tormach controller upgrade
- charliebrumfield
03 Jun 2016 14:40 #75433
by charliebrumfield
assuming not encoder feedback as no encoder is hooked up to the controller. (clear path does all that on the motor controller side)
03 Jun 2016 14:47 #75434
if its PCIE its a 6I25
Can you check the the 6I25 jumper positions match the default jumper picture in the 6I25 manual?
www.mesanet.com/pdf/parallel/6i25man.pdf (page 4)
- charliebrumfield
03 Jun 2016 15:18 #75437
by charliebrumfield
i'll check and report back. I have another mesa card I can toss in to test if needed. haven't finished setting up our pcnc 1100 yet so I can grab the mesa card from there if need be.
- charliebrumfield
03 Jun 2016 15:47 #75439
by charliebrumfield
jumpers are set just like page 4 of the pdf you linked. i'll swap the card with the one from the 1100 to see if that works. also you are correct the card is a 6i25.
- charliebrumfield
03 Jun 2016 18:15 #75455
by charliebrumfield
swapped mesa card for the spare we had in our 1100. exact same results. so it's not the card. going to reinstall path pilot and test stock tormach stepper to see if we can get a good part made.
03 Jun 2016 19:26 #75458
by cradek
Replied by cradek on topic PCNC770 4th Axis w/ Clear Path Servo & PathPilot
It looks like you lost your FF1=1 and now it's 0. Not sure what happened - it needs to be 1. Try FF1=1 and MAX_ERROR=0 as pcw has recommended.
Moderators: cncbasher
Time to create page: 0.214 seconds
