Spindle Encoder Mesa 7I76?
- Contract_Pilot
- Topic Author
- Thank you received: 11
08 Aug 2016 07:18 - 08 Aug 2016 07:29 #78480
by Contract_Pilot
Spindle Encoder Mesa 7I76? was created by Contract_Pilot
I have a Encoder On the Lathe and getting my wiring plan done for the 7I76 will be using Path Pilot with a Hitachi WJ200 VFD.
My Encoder is Driven 1:1 to the Spindle.
Options For Wiring On The Encoder.
Whats the recommended wiring for a Quadrature Encoder on a Mesa 7I76 for Turning & Accurate Threading? Searching gives conflicting/confusing info but most say all ya need is A+, ZR+, Common, & +5V Some say B+ Also? Some say just A+, A- and Some sites say if reversing motor for left hand threading/tapping Connect All? Confusing! Figured idd post this for the experts here to weigh in for correct info.
Also From the Model & Data Sheet Below this encoder appears to be Sq/wave Single Ended so I am assuming I want to also set jumpers W4,5,&6 to the left in single ended mode so if this is the cases my answer is in the manual!
Encoder Spec's From Data Sheet .
Model M21AASoDB4D-2000
SO Servo Mount
D : Cover Connector
B : Supply Voltage +5VDC
4 : Zero Reference Full Cycle
D : Sq/wave Single Ended
2000 : Cycle Per Shaft Rev.
When used with single ended encoders, the ENCA+, ENCB+ and IDX+ signals are wired to the encoder and the ENCA-,ENCB-,and IDX- terminal left unconnected.
SO Servo Mount
D : Cover Connector
Last edit: 08 Aug 2016 07:29 by Contract_Pilot.
08 Aug 2016 14:44 #78491
Replied by PCW on topic Spindle Encoder Mesa 7I76?
For threading you can get by with A and index only but you will get 4 times the resolution by using A and B (and index)
For rigid tapping you need A and B and Index
So if your encoder has A and B and index, use them all
If your encoder is single ended (= TTL) jumper the 7I76 encoder input for single ended
(your chart shows differential signals = a pair of signals for A,B and index))
Moderators: cncbasher
Time to create page: 0.207 seconds
