Want to build a PathPilot PC
31 Mar 2017 11:12 #90632
by cmark101
Want to build a PathPilot PC was created by cmark101
I can see this has been asked before, I am new to Linux. I have built Mach3 PC for my mill and it works fine I would like to change to PathPilot as Tormach wont sell a complete controller. I have found a some post with motherboard recommendations but they are either no longer available or no stock Could you advise some current spec boards to run PathPilot, I not looking for the cheapest but some thing up to-date. Any help would appreciated or point me in the direction. Thanks.
- brianTruck
- Thank you received: 7
31 Mar 2017 20:43 - 31 Mar 2017 20:43 #90666
by brianTruck
Replied by brianTruck on topic Want to build a PathPilot PC
I am just using an old xp computer ,nothing fancy (should have pci socket). My thought was to get most of the bugs worked out before I buy the exact computer that they recommend.
Get a good book on Linux commands. They seem cryptic at first ,but they will save you a lot of headaches once you learn them.
Invest in the mesanet.com interface boards , 5i25 -7i76 combo for stepper system and 5i25-7i77 combo for servo's.They make life a lot easier.
Brian
Brian
Last edit: 31 Mar 2017 20:43 by brianTruck.
The following user(s) said Thank You: cmark101
07 Apr 2017 19:22 #91011
by Sjdc1982
Replied by Sjdc1982 on topic Want to build a PathPilot PC
I'm using an old dell precision 380 with a quadro fx, with on board db25 and secondary db25 pcie. Got most of it working and moving just a few bugs here and there. But seems to be anything before the intel "I" series and sandy bridge is recommended.
08 Apr 2017 06:41 #91029
by cmark101
Replied by cmark101 on topic Want to build a PathPilot PC
Thanks for that, I have order a Intel Core i5-4460 LGA 1150 CPU and Gigabyte LGA 1150 Intel H81 mATX Motherboard GA-H81M-H also ordered 6I25 and 7I76 also got a Tormach PCNC 1100 Machine Control Board. So I see how I go when it all turns up.
08 Apr 2017 16:40 #91056
by smgvbest
Replied by smgvbest on topic Want to build a PathPilot PC
how did you manage to get the PCNC1100 Control board? do you also own a PCNC1100? just curious.as I tried and failed at that
08 Apr 2017 23:27 #91060
by cmark101
No I do not have a PCNC1000 I wish. Would like to get a PathPilot Controller from them
Moderators: cncbasher
Time to create page: 0.073 seconds
