Daughterboard inputs not recognized in HALMETER
11 Oct 2017 23:38 - 11 Oct 2017 23:39 #100246
by Dubmfg
Replied by Dubmfg on topic Daughterboard inputs not recognized in HALMETER
I've measured +24v to the pin when the limit switch is triggered. Pin 1 on SB6 is also directly wired from +24V on the power supply plug to it, as an always on signal for this testing.
Last edit: 11 Oct 2017 23:39 by Dubmfg.
12 Oct 2017 03:40 - 12 Oct 2017 03:42 #100254
by smgvbest
Replied by smgvbest on topic Daughterboard inputs not recognized in HALMETER
ok that's good, can you from a command prompt do a
dmesg | grep 6i25 and attach the output
also with pathpilot running in the MDI do a ADMIN HALCMD SHOW
then also attach your /home/operator/gcode/logfiles/pathpilotlog.txt
also, how are you running halmeter? are you starting it from within pathpilot with a ADMIN HALMETER?
please?
please?
Last edit: 12 Oct 2017 03:42 by smgvbest.
18 Oct 2017 00:57 #100495
by Dubmfg
Im using ADMIN HALMETER from within Pathpilot itself. Also, ADMIN HALCMD SHOW does not ellicit a response in Pathpilot.
I couldnt get a response in Terminal with dmesg | grep 6i25. Am I doing that wrong?
I've attached my logfiles
18 Oct 2017 02:57 #100497
Replied by PCW on topic Daughterboard inputs not recognized in HALMETER
Try dmesg | grep 5i25
18 Oct 2017 03:01 #100498
by Dubmfg
Derp, it reports as a 5i25. Shoulda remembered
18 Oct 2017 12:01 - 18 Oct 2017 12:02 #100504
by smgvbest
I see in your log you originally used the incorrect bit file and the last entry was the correct 5i25-7i76x2.bit
have you noticed any difference since that change?
the tormach bit file does not support the 7i76 so it would be suspected as a problem.
I'm at work and that was a quick look.
I wouild love to see linuxcnc and/or tomach to timestamp log file (pet peeve of mine)
Last edit: 18 Oct 2017 12:02 by smgvbest.
18 Oct 2017 14:10 #100509
by Dubmfg
Well yes, I swapped the bitfile for the 7i76 compatible one and am working on the .hal to use the inputs from the 7i76 instead of Tormach`s card. Where is the tormach timestamp logfile located?
20 Oct 2017 16:26 #100584
by Dubmfg
Ideas anyone? Ive been poking around forever and cant get anything meaningful out of my inputs still
20 Oct 2017 17:39 #100586
I would try LinuxCNC to verify the hardware
(and have access to known working tools)
22 Oct 2017 22:32 - 22 Oct 2017 22:32 #100638
Which pin names are you looking at?
I do most of my card testing at the command line to reduce the variables.
Copy and paste this into the terminal.
Now you can add the input bits to the halshow "watch" tab and see what happens.
Replied by andypugh on topic Daughterboard inputs not recognized in HALMETER
halrun
loadrt hostmot2
loadrt hm2_pci
loadrt threads
addf hm2_5i25.read thread1
addf hm2_5i25.write thread1
start
show pin
loadusr halshow
Last edit: 22 Oct 2017 22:32 by andypugh.
Moderators: cncbasher
