Problems with doing a toolchange
23 Oct 2017 03:55 - 23 Oct 2017 04:29 #100645
by DaOne
Problems with doing a toolchange was created by DaOne
I can not get my configuration to do a tool change. I have tried everything. All I need to do is a manual change no tool changer. Gang tooling to come later. If I command a MDI tool change or via the offset page I basically get locked out of MDI and the box used to choose a tool number in offsets page. I think I have everything set correct in my files. Could someone take a look and maybe give me a clue as to why this refuses to work? I also tried the sim config and it works like it should. Its gotta be something dead simple but I just can't find it.
Thanks in advance.
In the terminal I get this (I have to press reset to make MDI work again)...
Thanks in advance.
issuing MDI command: T3
emcTaskPlanLevel() returned 0
emcTaskPlanExecute(T3) returned 2
emcTaskPlanSetWait() called
LinuxCNC interp_state change was INTERP_IDLE is now INTERP_READING
reset button was pressed at -2017-10-22-20-38-16
emcTaskPlanSynch() returned 0
emcTaskPlanClearWait() called
Machine is moving. Not issuing MDI command: M30
LinuxCNC interp_state change was INTERP_READING is now INTERP_IDLE
Last edit: 23 Oct 2017 04:29 by DaOne.
- Thank you received: 1369
23 Oct 2017 05:12 #100648
Replied by Todd Zuercher on topic Problems with doing a toolchange
Shouldn't the command for doing a tool change be:
T3 M6
Tn prepares the tool to be changed, but M6 actually commands the change. (Need both even for manual tool changes.)
T3 M6
23 Oct 2017 05:20 #100649
by DaOne
Replied by DaOne on topic Problems with doing a toolchange
On a lathe M6 is not required. Also the MDI command is happening when I enter the tool number in the offset page. The sim files work just fine. I must be missing something in my config but I have went over them a ton of times and just cant find it.
23 Oct 2017 05:35 #100650
by DaOne
I tried the T1 M6 command and the result is the same I notice that I get "Machine is moving" in the terminal (debugger) when I try to change a tool and hit reset.
23 Oct 2017 07:03 #100653
by DaOne
"addf tormachltc.0 servo-thread" was the issue I guess its kinda required
All fixed
All fixed
Moderators: cncbasher
