LinuxCNC Forum
Toggle Navigation
Remember Me
Log in
Forgot Login?
Sign up
Index
Recent Topics
Search
www.linuxcnc.org
Hardware & Machines
Plasma & Laser
THC Cornerlock component
Start
Prev
1
Next
End
1
rodw
Offline
Platinum Member
Thank you received: 3279
17 Apr 2017 02:26
#91492
by
rodw
was created by
rodw
Here is a Plasma Cornerlock helper component.
This is designed to calculate a velocity including feed over rides that can be used to set up corner locks on the eoffset_pid component.
Instructions and an example are in the attached .txt file which is a dump of the man page.
Enjoy!
File Name:
cornerlock...4-16.txt
File Size:2 KB
File Name:
cornerlock...-16.comp
File Size:2 KB
The following user(s) said Thank You:
andypugh
Please
Log in
or
Create an account
to join the conversation.
Start
Prev
1
Next
End
1
Board Categories
LinuxCNC
- LinuxCNC Announcements
General
- General LinuxCNC Questions
- Installing LinuxCNC
- Documents
Configuring LinuxCNC
- StepConf Wizard
- PnCConf Wizard
- Basic Configuration
- ClassicLadder
- HAL
- HAL Examples
- Advanced Configuration
- EtherCAT
User Interfaces
- AXIS
- Gmoccapy
- Plasmac
- pyVCP
- GladeVCP
- PathPilot
- Other User Interfaces
- QtPyVCP
- Qtvcp
GCode and Part Programs
- G&M Codes
- O Codes (subroutines) and NGCGUI
- - Mill Library
- - Lathe Library
- - Plasma Library
- CAD CAM
- - Post Processors
- - - Fusion 360
- - - MasterCAM
- - - MecSoft
- - NativeCAM
Hardware & Machines
- Computers and OS's
- Driver Boards
- Milling Machines
- CNC Machines
- Turning
- Plasma & Laser
- Pick and Place
- Additive Manufacturing
Other Stuff
- Show Your Stuff
- Forum Questions
- User Exchange
- Off Topic and Test Posts
- - BeagleBone
International LinuxCNC Users
- Français
- Español
- Polski
- Deutsch
- Russian
- Other Languages
Moderators:
snowgoer540
Hardware & Machines
Plasma & Laser
Time to create page: 0.363 seconds
Powered by
Kunena Forum
