New laser setup questions
08 Jul 2017 17:51 #95508
by drksam
New laser setup questions was created by drksam
Hi everyone. I have a built a laser table and want to control it with linuxCNC. I have all of the motion and input/outputs working great. i can test fire the laser with the spindle and cut vector paths by using m3 m5. Now i would like to set it up to raster as well I found 2x_laser-master from jv4779 on github but it seems that it was built a few versions ago. the readme install sections says "based on an installed copy of the LinuxCNC 2.5 Ubuntu 10.04 LTS Live CD". I have 2.7.9 installed i did try to follow the directions but i ended with an error saying "comp: command not found" i googled that and found that i needed the dev package so i checked in to that and i already had the latest version.
So the questions are does anyone have an idea of hoy to install it on 2.7.9? Or does anyone have another solution to laser rastering that works in 2.7.9?
Thanks in advance for any help
08 Jul 2017 19:01 - 08 Jul 2017 19:02 #95511
Replied by PCW on topic New laser setup questions
To avoid a name conflict the LinuxCNC component compiler was renamed from "comp" to "halcompile"
Last edit: 08 Jul 2017 19:02 by PCW.
The following user(s) said Thank You: drksam
08 Jul 2017 22:11 #95518
by drksam
Replied by drksam on topic New laser setup questions
Thank you. It is working now.
15 Jul 2017 15:21 #95818
by shady
Replied by shady on topic New laser setup questions
Hello all
I've misunderstanding on how to install this configuration on linuxcnc
can you help me ?
can you help me ?
17 Jul 2017 12:49 #95888
Replied by andypugh on topic New laser setup questions
How far have you got, and at what point have you become stuck?
Time to create page: 0.070 seconds
