Torch isn’t firing
- Aldenflorio
- Topic Author
- Thank you received: 13
09 Mar 2022 17:27 #236762
by Aldenflorio
Torch isn’t firing was created by Aldenflorio
I have everything working but the torch isn’t being communicated with apparently. I wired it the way the diagram shows. Though the diagram isn’t showing a hypertherm 45 Which is what I’m using (not xp). I have the thcad-10. I used plasmac to configure it. I might have configured it wrong though. I will send my machine zipped in a few
- Aldenflorio
- Topic Author
09 Mar 2022 17:42 #236763
by Aldenflorio
Replied by Aldenflorio on topic Torch isn’t firing
- Aldenflorio
- Topic Author
09 Mar 2022 17:47 #236764
by Aldenflorio
09 Mar 2022 17:54 #236765
Replied by rodw on topic Torch isn’t firing
Your diagram does not show you have connected a 24v power supply to field power on the 7i96. Have you done this?
- robertspark
- Thank you received: 216
09 Mar 2022 17:54 - 09 Mar 2022 17:58 #236766
by robertspark
Replied by robertspark on topic Torch isn’t firing
are you using a machine torch or a hand torch?
www.google.com/search?q=hypertherm+hand+...imgrc=JSNGuvZWnbYJeM
www.google.com/search?q=hypertherm+hand+...imgrc=WoXoORDC9uJVnM
get a fine strand of wire and link pins 7 and 8 of the torch in the machine connector. the hand torch does not have this link, but the machine torch does which allows for the machine to be started remotely. it's a safety feature
Last edit: 09 Mar 2022 17:58 by robertspark.
- Aldenflorio
- Topic Author
09 Mar 2022 17:58 - 09 Mar 2022 18:02 #236768
by Aldenflorio
Yes I have. Also I am using a hand torch. I’m trying to open the links you posted. They are blurry thougg
okay I’ll try that!
okay I’ll try that!
Last edit: 09 Mar 2022 18:02 by Aldenflorio.
- robertspark
09 Mar 2022 18:01 #236769
by robertspark
I have posted a bit more info above
I will try to find some other links. some people rewire the connector but that is not required all you need is a very fine strand of wire and just make a U and use a pair of long nose pliers to get the link into position
- Aldenflorio
- Topic Author
09 Mar 2022 18:03 #236771
by Aldenflorio
Okay I’ll do that. If that’s all that needs to be done I would be so happy
09 Mar 2022 18:04 #236773
I am sure happiness will prevail
- Aldenflorio
- Topic Author
09 Mar 2022 18:05 #236774
by Aldenflorio
Do my ini and hal files look good?
Time to create page: 0.262 seconds
