Arc Ok Problem
- acourtjester
- Thank you received: 21
23 Feb 2024 18:01 #294095
by acourtjester
Arc Ok Problem was created by acourtjester
I am getting back into plasma cutting on my table, I am using QTPlasmaC and for some reason the Arc Ok does not seem to work.
I can see the Arc Ok In signal in Hal Show and have check the Hal file and the signal is shown attached screen shot. It will fire the torch 3 times before stopping. I changed the Mode from 2 to 0 no change. I checked the perimeters and the Arc volts hi and lo are as thee manual stated.
In the perimeters should the THC be set to auto start? did not see that until disconnecting the Plasma unit to put thing away.
I cut fine some time back when I started using the table of routing.
Thanks for the help
Thanks for the help
23 Feb 2024 23:14 #294139
by phillc54
Replied by phillc54 on topic Arc Ok Problem
If you have an arc-ok input then you require either Mode1 or Mode2. Mode2 would be if you have an external THC like a Proma or similar otherwise it should be Mode1.
Try a Halshow watch on pins db_arc-ok.in and plasmac.arc-ok-in, they both should be on when arc-ok is valid.
Auto THC should be fine if your plasma power supply is not noisy. This has no effect on arc-ok.
- acourtjester
24 Feb 2024 15:28 - 24 Feb 2024 15:33 #294219
by acourtjester
Replied by acourtjester on topic Arc Ok Problem
thanks
I am using the THCAD-10 so I will switch to the mode 1. I had manually changed in Hal from mode 2 to 0 now will change to 1.
For clarification when running Pnccof should I select mode 1 at that point.
Not having much experience with LinuxCNC but trying to learn.
I am working with another guy starting to build a Plasma table and may use LinuxCNC. Mesa seems to be out of stock on the THCAD-10. Your answer to me hints a Proma THC could be used.
Last edit: 24 Feb 2024 15:33 by acourtjester.
24 Feb 2024 15:46 #294220
Replied by PCW on topic Arc Ok Problem
The THCAD-10 and THCAD-5 have been replaced by the THCAD2
- acourtjester
24 Feb 2024 15:49 #294221
by acourtjester
thanks I will pass that along
- acourtjester
24 Feb 2024 17:59 - 24 Feb 2024 21:08 #294227
by acourtjester
The mode 1 change did not show a difference, I turned off auto volts and that made a big difference. But not with a normal cut plan it fails with a material list error #1000000. It fires the torch and errors out. Looked at the G-code there is material info lines but nothing about a list number. I changed the material list to the one posted for Hyperturm tool list for the metal thickness. Still fails I am using SheetCam and LinuxCNC PlasmaC post processor. Have a customer wanting cut parts that I cannot cut because of this problem.
Last edit: 24 Feb 2024 21:08 by acourtjester.
- acourtjester
24 Feb 2024 21:09 #294254
by acourtjester
Can the GIU Axis be configured to run Plasma????
- Thank you received: 6006
24 Feb 2024 21:20 #294256
Replied by tommylight on topic Arc Ok Problem
- acourtjester
24 Feb 2024 21:26 #294259
by acourtjester
Thanks I just found that myself, hope that gets me going to cut the parts then I can dig into why QTPlasmaC is failing. I did use it some time back so was surprised when I gave me a problem
Have fun
Tom
Have fun
Tom
24 Feb 2024 23:32 #294283
by phillc54
Material #1000000 is a temporary material. You G-code should contain all the material parameters.
linuxcnc.org/docs/2.9/html/plasma/qtplas...lasma:magic-comments
Time to create page: 0.261 seconds
