cannot import name collections_abc / ProbeBasic new installation failes
01 Feb 2022 09:18 - 01 Feb 2022 09:19 #233695 by RobertS
On a fresh install (2.8.2.11) from the updated Debian 10 Buster PREEMPT-RT ISO installation of the Probe Basic v0.x.x packaged failes with the error cannot import name collections_abc.
The failure is the same from version v0.3.4 until 0.4.0,
Find attached a screenshot and the relevant report files.
Any ideas?
Last edit: 01 Feb 2022 09:19 by RobertS.
01 Feb 2022 09:40 #233697 by RobertS
The issue is solved - at least for my installation:
  • pip show six
Version: 1.16.0
Summary: Python 2 and 3 compatibility utilities
Home-page: https://github.com/benjaminp/six
Author: Benjamin Peterson
Author-email: benjamin@python.org
License: MIT
Requires:
Required-by: pyudev
  • pip install -U six
Collecting six
  Downloading https://files.pythonhosted.org/packages/d9/5a/e7c31adbe875f2abbb91bd84cf2dc52d792b5a01506781dbcf25c91daf11/six-1.16.0-py2.py3-none-any.whl
Installing collected packages: six
Successfully installed six-1.16.0
Even the version did not change, after the installation ProbeBasic is working again (testet with v0.4.0)
05 Feb 2022 00:32 #234001 by P1-Engineering
I've been having the same issue.
How did you solve it exactly?. Don't really understand your message, completely new to Linux, just finished installing it 1 hour ago.
Thanks!
05 Feb 2022 09:08 #234015 by RobertS
try to follow these steps:
  1. open a shell window or do it directly on the console (thats what windows calls a "command prompt")
  2. just type pip -V
  3. you should get a reply like "pip 18.1 from /usr/lib/python2.7/dist-packages/pip (python 2.7"
    That shows you , the pip command is available
  4. type pip show six - the output should be like I mentioned in my 2nd post
  5. type pip install -U six - this should be install/reinstall the missing/wrong libraries
  6. start linuxcnc again
The following user(s) said Thank You: P1-Engineering
05 Feb 2022 18:54 #234037 by P1-Engineering
That did it, everything works now!.
Thanks a million Robert!
Now I just have to be patient till the Mesa cards arrive and I can start building the controller :)
Moderators: KCJLcvette
Time to create page: 0.363 seconds
