Probe Basic rapid override sliders bouncing
- COlger81
- Thank you received: 6
15 Dec 2022 17:28 #259566
by COlger81
Probe Basic rapid override sliders bouncing was created by COlger81
I converted from Gmoccapy to Probe Basic. I have a physical 3 position selector switch for rapid override which worked without issue in Gmoccapy. In Probe Basic it bounces the on screen slider at startup and periodically during operation when changing the physical switch. All pins are doing what they should be doing in halshow. I do not need to adjust that slider manually in the UI as i do use the physical switch. Any help would be appreciated.
Chris
Chris
- COlger81
15 Dec 2022 21:56 #259591
by COlger81
Replied by COlger81 on topic Probe Basic rapid override sliders bouncing
I was able to resolve the bounce issue with MUX16. Only issue remaining is on startup the slider does not sync with my rapid-override physical switch. It is defaulted to 100% and i have to flip the physical switch once every time I start the UI, then it follows my physical switch.
- Lcvette
- Thank you received: 673
16 Dec 2022 02:03 #259602
by Lcvette
Replied by Lcvette on topic Probe Basic rapid override sliders bouncing
How is the physical switch controlling the override? Is it a series of positions with latching outputs? It may need to be run through the post gui hal file to update the gui once it's been loaded. That would be my guess if it's a serious of latching switch positions outputting to various mesa inputs.
The following user(s) said Thank You: COlger81
- spumco
- Thank you received: 770
16 Dec 2022 04:47 #259608
by spumco
Replied by spumco on topic Probe Basic rapid override sliders bouncing
Yep - most stuff that interfaces with the PB screen works (or works better) when in the postgui.hal file. Physical SRO, FRO... stuff like that.
The following user(s) said Thank You: Lcvette, COlger81
- COlger81
16 Dec 2022 05:11 #259609
by COlger81
It's a 3 position physical switch with 2 outputs fed into MUX16. It works just fine after the first time switching it after startup. I'll move it to the POSTGUI in the morning and let you know if that solves it.
Thank You
Thank You
- COlger81
16 Dec 2022 16:43 #259654
by COlger81
The overrides work without issue now that i moved them to the POSTGUI.
Thank You
Thank You
The following user(s) said Thank You: tommylight, Lcvette
- Lcvette
16 Dec 2022 19:18 #259662
by Lcvette
excellent!The overrides work without issue now that i moved them to the POSTGUI.
Thank You
Moderators: KCJ, Lcvette
Time to create page: 0.065 seconds
